20 Most Recent
Shop Fox W1752 Mini Wood Lathe Questions & Answers
Fox mini lathe not running right
Could you be a bit more specific? This is a very simple machine...it either works or it doesn't. Have you checked the belt? Is it binding, or cross-threaded on the drive spindles?
Replace tire on top wheel
Check this
blog . This will surely help you . Check out bandsawparts.com or sawblade.com for good quality blades and tires. I got my stuff there.
Fox F36-522B table saw:
The blade
Hi, there is no lever or knob adjustment as such but if you look underneath where the motor and blade shaft mount in the carrier you can loosen the mounting bolts and twist the carrier in the direction required to align the blade then re tighten them.1 mm out of parallel is only half a mm of twist. Hope this helps, regards Phil.
Why my Makita disc cutter has spark wont start
If the fuel in it is 2 or more months old dump it out and put in fresh fuel and try statring. Also try try a squirt of starting fluid into the carb. If it fires on it you may need to do this a few times to pull the old fuel in the lines through till the fresh fuel can get to the carb.
4/10/2024 4:13:02 PM •
Saws
Answered
on Apr 10, 2024
