20 Most Recent
Sunbeam Cafe EM6910 Questions & Answers
Power button not working
There are many screws you would need to access...
However in 6 years of working on these I have never seen a power switch fail.. In most cases it is a bigger problem with teh main board and that usually means there has been a leak or some other major fault.
If your in Brisbane a simple fix for you - I can check out / repair. If not try
Crema Coffee Forum Index
No water coming through
Depending on if this is HW or Group water... But if you did not clean teh shower screen and group first; you have loosened scale and it is caught in the HW change over valve.
Why no steam.Sunbeam 6910 cafe series. Turned on steam wand this morning and all I heard was a sigh, a feint try to deliver steam but not successful. Very little pump noise / action almost non-existen
This could be 1 of many issues, usually the Steam pump (black or blue) is corroded and no longer vibrating correctly, the pump could be blocked, the pipe work after pump but before boiler could be blocked, the steam boiler could be blocked, the pipe work after steam boiler but before the steam tap could be blocked, the steam tap could be blocked, and also the milk nozzle could be blocked, if you feel competent to take it apart, it is easy to fix but if not take the machine to local service agent.
Sunbeam em6910 brewing does not stop
Before you start pulling the machine apart. Have a look at the grind sounds to course. Expecially if its taking 13seconds to pour... normal 60mls double shot should take from 25seconds to 28seconds. How many mls are your shots.. espressos are ment to be 30mls and double espressos are 60mls MAX.
If the grinds okay. Just simply re program the machine to above mls..
Feel free to contact me if you need.
