20 Most Recent
LG Smartphone P505 Questions & Answers
Forgot the pattern to unlock my phone
If you forgot unlock pattern, depending on the phone if it android you should be able to access the option of entering your gmail account information after trying to many times within a time period that what happen with my lg p925g.
Wont do anything
Mine just quit too. When trying to start it, the buttons
illuminate followed by the "LG" logo on the display for a second and then it
all goes off. When on a charger that sequence repeats itself nonstop. In the
last week the phone shut off by itself two or three times but did start
afterwards. The warrantee expired last month. My solution will be to throw it
at an appropriate person at AT&T or LG.
Lg p505 says no sd installed
If there is one there, take it out and put it back in again and see if it still says that...sometimes the contact points lose their connection for some reason...
Lg fb163-how to add bluetoth function
To add Bluetooth functionality to your LG FB163, you can use a Bluetooth adapter that is compatible with the device. Ensure that the adapter you choose is compatible with the FB163 model. Once you have the adapter, follow the instructions provided with it to connect it to your FB163 system.
To connect your Android phone to the FB163, you'll need a compatible cable. Typically, you would use an auxiliary (AUX) cable with a 3.5mm jack on both ends. Plug one end into the headphone jack of your Android phone and the other end into the AUX input port on the FB163 system. Then, select the AUX input mode on the FB163 to hear the audio from your phone through system.
How can I hatd factory hard reset my LG 265 if I don't have my pin # nomore or forgot it .
- Turn the phone off.
- Press and hold the Power/Lock key (on the right side of the phone) and the Down Volume key (on the left side of the phone) at the same time.
- When the Factory data reset screen appears, release both of the keys.
- Use the Volume keys to highlight Factory data reset, then press the Power/Lock key to confirm.
- Use the Volume keys to highlight Yes, then press the Power/Lock key to confirm one more time.
- Your phone will perform a factory reset.
Im locked out of my
WARNING : Performing a hard reset will remove ALL data including the Google account, system data, application data, application settings, and downloaded applications.
- With the phone off, press and hold the Home key, Volume Down key and Power button. When the LG logo appears, release only the Power button.
- Release the Home key and Volume Down key when the Android icon appears.
- Follow the on-screen instructions.
