20 Most Recent
Husky HUS-CN15 Wine Chiller Questions & Answers
Fridge is not getting cold, fans are running and outside casing feels cold to touch but internal warm think faulty compressor how can check and how easy to chnge
If fans are running and compressor is not check to see if the unit has a starting capacitor for the compressor - check it for capacitance value and change if necessary. If still nothing, using a voltmeter check to see if current is reaching the starting windings of compressor. If nothing, then maybe the thermostat is defective. But if current appears at terminal and the start capacitor is good, then the motor has definitely gone to heaven.
if compressor is running and refrigerator is warm, either the self defrost mechanism is not working or perhaps you may be in need of refrigerant.
To change unit you need vacuum pump, solder and soldering equipment, schrader valve, refrigerant scale and refrigerant, gauges, rags, emery paper, etc.
The temperature will not adjust. none of the
Sounds like you may have a compressor issue to me. if the fans are running that tells me the tstat is calling for cooling and the fans are running so they are fine. The comp is not producing cooling for some reason. Can you see the comp and tell if its running or not?
Husky cn15 88 problem
First things first, check the power supply. If there is power at the pluf then I would look at the temperature control. Check to make sure it is closing and calling for the compressor to be coming on, that will also control the condenser fan motor.
Good luck
