20 Most Recent
Bissell 2X Proheat 9200 rug cleaner Questions & Answers
Brushes not turning
It could be the belts. They are pretty easy to replace. Check the bottom of this tutorial http://www.diyvacuumrepair.com/carpet-cleaners/how-to-fix-a-bissell-proheat-that-wont-spray/
Bissell carpet shampooer model 9200-9 that is not dispensing cleaning solution
I had the same problem with my Bissell carpet cleaner. I tried all the recommendations but nothing worked. After reading all the blogs, I discovered that many people had the same problem. Fortunately, I still had the receipt from Costco which they honored and gave me a full refund. I was ready to throw it in the trash.
Water will not spray on my Bissell Proheat 2x Carpet cleaner
proheat 9300assuming the water will flow with the tool attachement but not to the carpet.Remove the water tank. You will see 2 red tabbed plastic spray tubes.(where the spray comes out if not clogged) Pinch the clips to remove from the machine. Then you will need to pinch the hose clips to remove the red tabs from the hose. Clean out those red spray nozzles. Next step: have a towel ready and fill the solution tank with water. Put the solution (not water) tank on to where the water tank would go. Place the machine selection knob to rinse/wet only. Now with towel under the hoses that you removed the red tabs. Turn on the machine and pull the trigger to activate the water. You should see water flow out of the hoses that had the red tabs on them. If not, release and pull again the trigger several times. If only 1 hose has water coming out of it then block the one that works and try the process above again to de clog the one that isn't working. Good luck.
Motor rewireing
Call there technical support line, it may be the wrong motor. if not they are very good about taking you step by step on the rewire.
