20 Most Recent
Husky 3650 Watt Generator with Subaru Engine Questions & Answers
What kind of oil?
It actually depends on the environment but you will be okay with 10W30
Won't generate power
Need to replace the brushes on the dynamo and have the wire coil checked for shorts. Take to an expert to have the coil checked/ varnished.
3650 generator won't start!!
I assume that the spark plug are good and the gas line is clear. Try to adjust the gas line supply and default engine startup revolution settings try it full half and minimum back and forth it works. Other gen sets requires a mix of oil with its gas, please do it when it is required with exact proportion. Hope this helps. Goodluck.
Geberator runs put no power on the outlets
I had the exact same problem. All i did was take off the fuel tank, take off the heat plate take off the the plug that goes to the outlets then i took off the cover to the brushes to the solenoid i cleaned it with sand paper very lightly, i wiped it down with electrical cleaner, i put it back together and it worked perfect. i usually dont do this but if i can be of any help feel free to call me at (432)235-0026 if i dont answer please leave a voicemail i will call you back nut i hope this was help enough.
