Extended Systems Pocket Print Server
Problems with Extended Systems Pocket Print Server?
Keep your PC up-to-date. Get a Free Scan for Extended Systems's latest driver updates.
Troubleshooting and Support
Solved Problems for Extended Systems Pocket Print Server RSS Feed Post a New Problem
cannot find print server at all
I cannot find the my extended systems print server at all. It is a ESI-2831. I seems to be set to have a static IP...
2 Solutions
ESI-2831 Drivers missing
I inherited a job that has 3 esi-2831 pocket print servers , and the drivers or manuals are no where to be found, can...
3 Solutions
Can't find printserver on the network
I have inherited from the previous personthat had this job a ESI-2831 printserver that I can't identify on my network. I...
1 Solution
DRIVER DU SCANNER UMAX ASTRA 3600
GET HELP TO FIND DRIVER FOR SCANNER UMAX ASTRASLIM SE
1 Solution
lexmark Z1420
i need disc for lexmark Z1420, so i can add to my windows vista
1 Solution
Network printer not printing properly
I have a network printer that is not printing all the text I send to it. Another lap top on the same network has no...
1 Solution
Linksys WPS54G
Running the setup it finds the WPS54G server,IP 198.168.0.101, but after hi-lighting, and clicking next, after a delay,...
1 Solution
Unsolved Support Problems
Unsolved Problems for Extended Systems Pocket Print Server RSS Feed Post a New Problem
Tension
I, Quelle est la tension d'utilisation 5vcc, 8vcc, 12vcc ??? Merci
Post a Solution
ESI-2831
Hi. I'm looking for the software for ESI-2831. Do you have it?
Post a Solution
Tips & Tricks
Post a New Tip
WikiManual
Post a New Chapter
Manuals & Guides
Post your Manual or Guide
Specifications
Key Features
PlatformMac, PC · PC
InterfaceParallel
Form FactorExternal
Data Transfer Rate10 Mbps
ConnectivityCable
Cabling TypeEthernet 10Base-T, Ethernet 10Base-2 · Ethernet 10Base-2, Ethernet 10Base-T · Ethernet 10Base-T
Other Features
Package Qty.1 · 50
Data Link ProtocolEthernet · Ethernet, EtherTalk
Remote Management ProtocolSNMP · SNMP 1
Warranty
Warranty2 Years · 5 Years
Supported Models
ESI-2830A, ESI-2831A, ESI-2835A, ESI-2836A, ESI-2836A-EUR, ESI-53831, ESI-53831A, ESI-53833A, ESI-53836A
Sponsored Links
Loading problems.
Top Experts
Ask Me
1divebum Master
2 solutions
Ask Me
ImWireles Guru
1 solutions
Ask Me
Silverdra Wiz
1 solutions
Repair Service
Find Print Server Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
