20 Most Recent
Dell Inspiron N5030 Notebook Questions & Answers
Speaker jack
Hi, First look if audio is turned off on Laptop. It's a volume icon on lower right or upper F buttons. Second look at audio plug on laptop Make sure not loose or broken inside. If all is good, might be software issue on laptop. Take to shop for repairs. Hope that helps.
No webcam detected laptop
Try re-installing the webcam driver from here:
http://www.dell.com/support/drivers/uk/en/ukdhs1/Produc...
(Click the "Drivers & Downloads" tab).
If that doesn't fix it, and there are no driver errors showing in Device Manager (ie no question marks or exclamation marks) then it's very likely that the internal webcam has broken and Windows can no longer detect it.
You can buy an external webcam to overcome that problem.
My laptop headphone no working
Do you mean the round outlet/socket?First, you may to check if the headset (or speaker) is good, especially there are no worn out wires and the jack is good. Next, the speaker is in the ON position or not MUTED.The speaker socket can still become rusty, you can spray some contact cleaner to loosen the rust.Good day.Continue Fixya,Tedmac
Microphone not working settings
you must sure if the microphone is working, will be a great idea that if you can test in another computer, in that way you see if it is the computer or microphone.However you must try to restore go to control panel, use the utility system restore, and put the last date that you know was working Good.Or open the sound in control panel and RUN the troubleshooting in tab for microphone.God bless you
Error 0x400110020000100a
Unfortuneately you will need to go online, contact customer support and the technical department to order a new recovery disc for your make and model of laptop.
Dell inspiron n5030
Have you tried restoring the computer to the original factory configuration? If you did not have the problem when you first received the laptop, the restoration will fix it. (Page 70 of the Setup Guide -- Factory Image Restore).
If the restoration fixes it, that means that some configuration change caused the problem, most likely an update. If you keep track of future updates you can discover which one triggers the problem when it recurs.
If the restoration does not fix it and the computer did not originally have the problem, that means that a hardware problem has developed.
How do you install a hard drive
Larry provides great answer up there ^^^ which is better down here.
Larry Ng Jun 23, 2022
NO PC told (dell has 10000 models)
no OS told, windows what"?
no drive told.
my wild wild guess is the boot drive is locked.
and you are attempting and ******* act. to it.
like deleting key parts of a running OS (windows) (like deleted tires on rims of 85mph moving car, fails)
no real goal told, but the nebular "install HDD"
one can add a 2nd drive easy or any of 1000s of external HDD models or external or internal, SSD or even a thumb drive. (vast) (just 2 steps in fact)
but the boot drive , change out is far far far more complex. and you never not told that.
you want to mess with the C: drive?
now let me guess the real goal (sad I must)
the OS drive windows is failing ( common)
and some lil' bird told you it needs a new boot drive, and then fail to say so here.
okay I will bite.
1: buy a new SSD (hdd fail and are slow)
2: buy a new OS, from MS. or get free w10. (ask how)
3: then put in new SSD,
4: run the w10 installer media (it is free)
5: load w10 to the SSD fresh
6: answer the silly 30 questions it asks.
7: and click activate. (buy it)
How do i change admin password
can;t log in now or what?
what does change mean,
lost it and now can not get in
or means just want to change it , logged in.
NO PC told and NO OS told
or if bios admin or windows admin.
bios or windows.
both are hacking./ if lost.
so google the cure.
How do i eject a cd from the laptop
push the physical cd drive try button marked EJECT
the PC must be running,
or use the paper clip hole trick. (if PC is dead or tray jammed)
google that. clip trick
the dell manuals covers this
How to delete bookmarks
google dead ?
first off my PC has 4 browsers.
all 4 different answer.
IE11 ( or OMG 1 to 10 )
Edge
Chrome.
Firfox v95 (click tab book marks then click manage BM, the right click any or all you see and delete.
learn google
like
google IE11 bookmarks delete.
and read, millions of hits world wide all true.
