20 Most Recent
TDK (ai+420n) DVD+RW Burner Questions & Answers
Medium not present
make sure all leads that are attached to your cd/dvd have secure connections and are not faulty or just replace them they could be faulty ?
you might have to physically unplug the cd/dvd drive restart your computer this should activate the found new hardware wizard
Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose DeleteAfter deleting the keys, close the registry editorReboot your computerOpen My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps you
Computer is asking me to format my TDK usb drive
Please restart your computer once before attempting to access your external drive again. If this issue continues, please temporarily use another computer to access the drive and run a virus scan on your windows 7 computer. Thank you.
Can't get it to open
There is always a hole in the front of the tray. Just put a paper pin through it and press gently. It will release the tray lock manually.
Model DA-3826
electronic engineers/repairs will are the ones that would help to fix your player.
I would not know where you can find them because I am sure we don't stay in the same location.
I would advice that you search for local electronic repairer within your area or if you can locate the store of the maker/producer of your Player so that the repairs can be carried out.
Take care.
Tape life
it depends on which tapes are used.. it should be on the packing of the tapes themselves, it should tell you how many write cycles they are good for... just like video tapes and audio cassetes these tapes wear out in the same way.
Como cancelar el winter driver
EnglishIt is a car, and cars are complexbut no car was told , maker, model , and year.we can not guess cars. post the VIN? and all that is knownname a problem what can't your car do right?name symptoms or evidence that is confusing to you.then answers can happen.onlygood luck , finding itand Mucho Gusto.my guess now is this is posted to computer forumand not to CARS !must be some odd traction controls thing'but 10,000 models of cars,
I need a product key
Have you actually purchased Visio, or are you just trying to get it for free?
As a software guy, I would have to advise against piracy. :)
There are several ways to get Visio for cheap. If you are a student, there are discounted versions available online and in stores. Also, you can check with your school for even cheaper options sometimes. Try the university bookstore if available. Or a Computer Science department maybe.
If you are working, and your company uses MS Office applications, find out if they have the "Microsoft at Home" program. You can get MS Office applications for really cheap that way. I can get Visio through my company's "Microsoft at Home" program for a few dollars.
