20 Most Recent TDK (CD-RW74HSFXS5) Storage Media Questions & Answers
Download Partition Wizard and install it. Put your 4GB drive in and open Partition Wizard and click on your 4GB drive. On the left side click wipe partition and click format then click apply and wait. Now your drive is completely blank and all 4GB are back. Hope this helps.
TDK... | Answered on Dec 15, 2017
Stick is probably formated in NTFS file format. Windows XP cannot read that, only FAT 16 and FAT 32
TDK... | Answered on Dec 03, 2017
Reformat with this utility.
http://www.pcworld.com/downloads/file/fid,64963-order,4-page,1/download.html
TDK... | Answered on Aug 15, 2015
Do you have a proper antivirus program (NORTON , AVG , KASPERSKY) cos sometimes due to viruses and cookies filled computer can not detect a usb ...
TDK... | Answered on Jun 18, 2014
w7
First, please disconnect all USB devices and then perform the following steps:
Click "Start" button, type "devmgmt.msc" (without quotation marks) in the "Search" bar and press "Enter". Click "Continue" if necessary.
In Device Manager, double click to expand "Universal Serial Bus controllers", right click on the Host Controller, click "Uninstall" and click "OK".
Repeat the step 2 to uninstall all items under "Universal Serial Bus controllers".
Then, restart your computer and Windows 7 will reinstall all USB controllers automatically.
for xp or earlier
click start right click on computer select properties device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X
you will need to update/reinstall drivers
right click to reinstall drivers
if you can see your usb drive but its not working
ports (com&lpt) right click update driver if this fails to fix the problem
check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems to a computer and its parts
if you need more help with this or if i have missed the problem post a reply
hope it helps
TDK... | Answered on Apr 30, 2014
You have to be the computers administrator to change any values on any hard drive on your computer
click start control panel user accounts on the users tab click the name of the computer administrator you must have full control
click start click to open on my computer you should see your usb drive could be E: or something right click select properties there will be an array of options
select the sharing tab option then advanced sharing make sure you have a tick in the share this folder box
then click permissions make sure you have all 3 boxes ticked full control changes and read in windows 7
click start control panel user accounts click on the administrators account if you have made one or you will have to create one in windows XP
click start right click on my computer select open
Right click the icon of your usb drive (It should be E:/ or something)
Click Properties in the menu that comes up
Click the Sharing tab
Click permissions
And finally, click Allow next to Full Control.
if you need more help with this post a reply
then you might restore it to its default status
Right click on usb drive select properties you will have an array of options
Select the hardware option then select your drive properties policies
restore defaults
In XP
Right click on your drive select properties then on customize restore Default in W 7
If you need more help with this post a reply
hope this helps
TDK... | Answered on Sep 24, 2012
Click permissions
hope it helps
TDK... | Answered on Jul 09, 2012
Click permissions
hope it helps
TDK... | Answered on May 03, 2012
if you are referring to cd/dvdrw
Click start control panel administration tools computer management device manager scroll down cd-dvd rom drives you might see a yellow question /exclamation mark ? ! or a red X right click to update driver
you might have to physically unplug the leads for this cd/dvd restart your computer then plug them back this should activate the found new hardware wizard
if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps you
TDK... | Answered on Apr 05, 2012
http://majorgeeks.com/Dr._Freeware_System_Utilities_d6416.html Dr.Freeware System Utilities which includes data recovery software, data backup, password reset tools for Windows helps you to maintain your system. Dr.Freeware is freeware, you can download and use it for free.
Hope this helps
TDK... | Answered on Mar 20, 2012
TDK... | Answered on Nov 01, 2011
TDK (CD-RW74HSFXS5) Storage Media Logo
76 questions posted
Top TDK Electronics - Others Experts
Alun Cox
 Grubhead
Grubhead
Jim Goldsmith
Jim Goldsmith
Are you a TDK Electronics - Other Expert? Answer questions, earn points and help others
View Most Popular
  • TDK Electronics - Others
Most Popular Question
pc not read 16gb tdk usb flash drive
  • Electronics - Others
