20 Most Recent JVC KWAVX640 Car Video Player Questions & Answers
JVC In-Dash CD Receiver - KD-G140. Wiring diagram for kd g 140 JVC please?
Question edited for full 'make model (what it is)'. Installation and User Manual. Wiring diagram is on Page 4. https://www.manualslib.com/manual/81350/Jvc-Kd-G140.html#manual ..
3/31/2024 6:54:49 PM • JVC Car Audio &... • Answered on Mar 31, 2024
JVC KW-V940BW Car Play, Android Audio, Bluetooth and USB stopped working
See page 77 troubleshooting of user manual for help B5A-2488-00_KWV_M_EN.pdf (jvckenwood.com)
2/14/2024 2:14:33 PM • JVC Car Audio &... • Answered on Feb 14, 2024
My JVC KW-XR610 comes on then shuts off just started
See page 4 of manual (Troubleshooting) Install_KW-XR610[J]f.indd (jvc.com)
1/7/2024 10:38:28 AM • JVC Car Audio &... • Answered on Jan 07, 2024
JVC KS 102 car amplifier. Wiring diagram for it please?
Question edited for clarity. Turn question around, add magic word. https://www.google.com/search?q=JVC+KS+102+car+amplifier.+Wiring+diagram ..
12/22/2023 12:59:42 AM • JVC Car Audio &... • Answered on Dec 22, 2023
JVC model kw-av70bt is in production mode how can I change it
Download the user manual and follow corresponding instructions ManualsLib - Makes it easy to find manuals online!
10/11/2023 12:37:03 PM • JVC Car Audio &... • Answered on Oct 11, 2023
Owner manual for Stereo Cassette Deck JVC KD-720
Owner Manual isn't found, as there is a car stereo with a similar number. A standalone Cassette deck only supplies a data signal, so you need and amp. https://www.google.com/search?q=%22JVC+KD-720%22+manual
JVC KD-G720 Instructions Manual
ManualsLib https://www.manualslib.com > manual > Jvc-Kd-G720 View and Download JVC KD-G720 instructions manual online. JVC CD Receiver Instructions. KD-G720 car stereo system pdf manual download. Also for: Kd-ar770, ... Service Manual https://www.hifiengine.com/manual_library/jvc/kd-720.shtml
9/1/2023 12:26:57 AM • JVC Car Audio &... • Answered on Sep 01, 2023
My JVC-SD5 lights up, plays Music, but the lid won't open, any suggestions?
It seems like you're facing a little hiccup with your JVC-SD5. There's some troubleshooting ideas... Firstly, make sure the CD player is powered off and unplugged from the electrical outlet. Safety first, right? Now, take a good look around the edges of the CD lid. Sometimes, dust or debris can accumulate and prevent it from opening smoothly. Grab a soft, lint-free cloth and gently wipe the edges of the lid. Make sure to remove any obstacles that might be blocking it. If that doesn't do the trick, let's try a little trick called the "manual release." Look for a small, pin-sized hole near the CD tray. It's usually located either on the front panel or underneath the CD player. Take a paperclip or a small, pointy object and insert it into that hole. Apply gentle pressure to trigger the manual release mechanism. This should pop open the lid, giving you access to your beloved CDs. Once the lid is open, inspect the CD tray and the surrounding area for any visible signs of damage or obstructions. If everything looks fine, try closing and reopening the lid a few times to see if it starts functioning properly. Sometimes, a little exercise can go a long way in resolving minor glitches. I hope these suggestions help you get your JVC-SD5 back in action and free you from that unwanted station! If you have any more questions or need further assistance, feel free to ask. Good luck!
8/14/2023 7:05:37 PM • JVC Car Audio &... • Answered on Aug 14, 2023
My JVC stereo 6020 not making noise
i kindly recommend that you check volume level is not set to mute.Also,ensure that the stereo is properly connected to the speaker.check if the speaker are working
8/12/2023 5:30:35 AM • JVC Car Audio &... • Answered on Aug 12, 2023
How to reset the clock on a JVC pc-110 boom box 1994 model?
To reset the clock on a JVC PC-110 boombox from 1994, follow these steps:
  1. Press the Clock Set button, located on the top of the boombox, to enter clock setting mode.
  2. Press and hold the Clock Set button until the hour digits on the display start flashing.
  3. Use the Fast Forward and Rewind buttons to adjust the hour to the correct time.
  4. Press the Clock Set button again to move to the minute digits. The minute digits will start flashing.
  5. Use the Fast Forward and Rewind buttons to adjust the minute to the correct time.
  6. Press the Clock Set button one final time to exit clock setting mode and save the new time.
Your JVC PC-110 boombox should now display the correct time.
3/3/2023 6:11:40 PM • JVC Car Audio &... • Answered on Mar 03, 2023
How to reset password for jvc kw-v850bt
The process for resetting the password on a JVC KW-V850BT car stereo may vary depending on the specific model and software version. Here are some general steps you can try to reset the password on the JVC KW-V850BT:
  1. Disconnect the battery: Disconnect the battery of your car for at least 30 seconds, then reconnect it. This will reset the car stereo to its default settings.
  2. Press the reset button: If your JVC KW-V850BT has a reset button, press it and hold it for a few seconds until the unit restarts. This should reset the password to the default setting.
  3. Check the manual: Refer to the manual of your JVC KW-V850BT to see if there are any specific instructions for resetting the password.
  4. Contact the manufacturer: If you are still unable to reset the password, contact JVC customer support for further assistance.
It's worth noting that depending on the model and software version, the option to reset the password may not be available. In that case, you would have to contact the manufacturer for further assistance.
1/12/2023 12:49:21 PM • JVC Car Audio &... • Answered on Jan 12, 2023
How to set fm channels on my jvc KD421
Tune the desired channel and press and hold the desired button until it shows stored.
1/7/2023 11:12:54 AM • JVC Car Audio &... • Answered on Jan 07, 2023
How to wiring jvc kd-r690s?
To wire a JVC KD-R690S car stereo, you will need to connect the power, ground, and accessory wires to the appropriate terminals on the back of the unit.
  1. First, locate the power, ground, and accessory terminals on the back of the unit. These are usually labeled "Power," "Ground," and "ACC," respectively.
  2. Connect the positive power wire (usually red or yellow) to the "Power" terminal on the back of the unit.
  3. Connect the negative ground wire (usually black or brown) to the "Ground" terminal on the back of the unit.
  4. Connect the accessory wire (usually blue or blue/white) to the "ACC" terminal on the back of the unit.
  5. Make sure that all of the wires are securely connected to the appropriate terminals.
Keep in mind that the specific wire colors and terminal locations may vary depending on your vehicle and the specific model of the JVC KD-R690S car stereo. You may want to consult the owner's manual or a wiring diagram for your vehicle and the stereo to make sure that you are connecting the wires to the correct terminals. If you are having difficulty wiring the JVC KD-R690S car stereo or if you have any other questions, you may want to consult a professional installer or JVC customer support for further assistance.
12/24/2022 12:20:32 PM • JVC Car Audio &... • Answered on Dec 24, 2022
Room for speakers
Hello jarvis40,
You did not say exactly what improvements you want to make, what your budget is, nor if you are looking for a stealth install.
First I'd recommend that you look at what some other owners have done and see what you like. The MR2 Owners Club Forum would be one place to start. Many times you will find unbiased reviews of specific gear. There are installs documented with photos, and detailed step-by-step procedures. Generic car audio forums are also good. For comparing equipment and pricing, you simply cannot beat Crutchfield. The prices at Crutchfield are generally lower than you will find at your local audio dealer, but somewhat higher than other online stores. But they are excellent for doing research and if you do buy from them, you will find that the extra dollars paid buys you the absolute best service available.
If you're looking just to add an amp and a sub or two, and want a custom look instead of a "big ugly box", you might want to check out Concept Enclosures. He constructs custom boxes to fit specific places. Sort of like the JL Audio stealth box, or MTX Thunderforms, but less expensive. He has a design for the MR2.
And if you just want to change out your factory speakers, while you are browsing the Crutchfield site, check out the Focal speakers. The Utopia Be NO. 7 is simply the best 6.5 " 3-way component automotive speaker system in the world period. But if your budget won't stretch for the Focal's, consider the Alpine SPS-600C component system. They sound amazing.
Hope this helps.
12/19/2022 1:48:53 PM • JVC Car Audio &... • Answered on Dec 19, 2022
Why is my display blinking on my JVC kdr 304 car stereo
Hi, Please restart the car stereo a few times in order to attempt to overcome the issue. If that fails, then we can restart the car as well. Otherwise, you can check the fuse within the fuse box next in order to see if it's damaged at all and replace it if necessary. Thank you.
12/8/2022 1:55:33 AM • JVC Car Audio &... • Answered on Dec 08, 2022
JVC KWAVX640 Car Video Player Logo
4 questions posted
Top JVC Car Audio & Video Experts
xxxxxx xxx
ZJ Limited
ZJ Limited
 Grubhead
Grubhead
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
View Most Popular
  • JVC Car Audio & Video
Most Popular Question
jvc sd5 lights up plays music but lid
  • Car Audio & Video
