20 Most Recent
Pantech Impact P7000 Cell Phone Questions & Answers
Does anyone have a free unlock code for my Pantech
hi there are many online sites found nowadays that provide free unlock codes .but they didn't provide codes for newer mobile model .you can get the unlock codes from here
superunlockcodes here they ask the following details before providing the codes they are
model of the mobile , country from where you brought the mobile ,provider to which the mobile is locked then the imei number of the mobile .finally they will send you the codes to unlock the mobile .once you entered the codes in your mobile as for the instruction provided by them your mobile get unlocked and accept all network sim.
Trying to usea prepaid sims in the phone and it is
To be able to use any prepaid or post paid sim on your phone, I can offer you my service thru Pantech online unlocking service,please give the following information of your phone to unlock your phone easily.
* IMEI number ( located at the back of the phone labeled by Pantech)
* Country
* Network lock
No need to wait for lock because the code is instant.please click the link below and let's get started.
PANTECH UNLOCKING SERVICE
Best Regards,
Deleted all my songs from phone
Download a file recovery software and install into a computer. install the exe file and run program, then connect your phone in to the computer and select masstoreage mode. go to the program and select the phone storage and you will get your old files.try it .remember it's a slow process.
Insert sim card
First All Check:1.Confirm whether same sim card is working in other h.s or not.2.Make sure the sim slot is o.k. only try these two.3.If all the above steps fails, check the SIM card connector pins for damage.if so try to get serviced. 4.if ur sim card is good then it is problum form sim card ic u have u raplace it with SMD.u can make it jumper mean u can fix this prob with out sim card is for this contact.5.take sim connector slight up by pin then cheak by inserting sim.6.hot air gun on sim i.c. then cheak it.Last Option:IF make sure that the sim card hasn't been damamged at all sO Please You Go to Service& Sim Office and Get the Duplicate Sim Same Your No From Office OpratorProblem will Solved Quickly
