20 Most Recent
Jwin Jsp204 Questions & Answers
Drivers for jwin js-p204
The usb drivers for this speaker are included in the OS. Update your mac OS. If you still have a problem the speakers are probably broken.
4/13/2014 8:58:41 PM •
Jwin Jsp204
Answered
on Apr 13, 2014
Have had this JWIN model JK-777 turntable/am-fm/cassette/cd player unit. It won't power on now. Checked the outlet, no problems there. Does this unit have a fuse?
1. It's more likely the problem is a broken power cord or dirty power switch. If you've been in the habit of yanking the cord to unplug the unit instead of pulling directly on the plug, or somebody tripped over the cord, the power cord is probably broken right at the plug.
2. Changing a blown fuse without finding and repairing the fault that blew the fuse will only give you another blown fuse. It's not like the old farmhouse with too many things plugged in on the same fuse... A blown fuse in audio equipment is usually the result of a shorted speaker driver transistor. The transistors come in pairs; if one is bad the other has been overloaded and should be replaced also. That's a job for an electronic technician.
My mp3 wont play songs that i put
My jwin jx-mp101blk quit when I deleted the folders in it to make room for saving stuff. It still works as a memory stick, but won't play. What are the needed files?
How to i format music to mp3
You need to use a video converter to deal with the format problem.Go and have a try for this one which I have used for long,it will help you easily convert the music to Mp3.here is the link for this good
video converter.
It say file system error
File System Error meaning that you have a corrupted program. Re-installing the program is the only solution. Unfortunately, all files will be deleted.
It would be best to contact the manufacturer and have them re-program the device with the version that would work best.
Good luck and have a good evening!
