20 Most Recent
Toshiba Tecra M2-S410 (032017233812) PC Notebook Questions & Answers
I have a Toshiba Tecra-M2-S410 machine, and it
Hi mohammad - seems the LCD of the laptop is gone bad .
as u said u gets the light on the laptop and also sound and then it goes dark - shows possibly the LCD gone bad .
Give a try with this if you have a computer in your home - on the back of the monitor you will find a VGA cable (probably with a blue color end which goes to cpu ) unplug it from cpu and plug it in the laptop (side of laptop you will find a same input VGA slot blue color ) and boot your laptop after turning on both (monitor and laptop) if you find the screen on the monitor then it will be sure that your laptop LCD has gone bad .
On your laptop if you are not able to find the boot screen also that refers to LCD brokerage -anyway try the above you will be sure ..
Built in hdd error
remove the hdd and attach to desktop .
right click in my computer and run check disk in tools section in drive properties
Toshiba tecra s3 supervisor password reset
1. try with clear cmos and remove AC adapter and main battery.
2. also pls try to remove the code with password re set web site or password remove tool in hiran boot cd
Toshiba tecra no image
need more information to determine the fault. but you can remove the battery and pls plug ac adapter and also re seat the RAM. power on and test
My phone is not turning on
I have had this on an iphone 5. Apple sold me a new phone as it was not worth repairing and it was out of the 12 month warranty. Its possible to order a new part and do it yourself but unless you are totally confident and have the skills to open up your phone and reassemble it then its just not worth it.
Tecra s10 display brightness
look closely at the keys along the top of the keyboard (usually called F keys). one of them should have a tiny sun icon and the key beside it will have a larger sun icon. hold down the "Fn" key elsewhere on the keyboard while pressing the one of the sun icon keys to brighten or darken the picture. the sun icon keys may also be located on the Arrow keys (<-- --> etc.)
How to remove dvd drive
When does it open on its own?Sometimes it is easy to be press the open button as you close it which of course opens it straight away.It can also fail to lock closed if not opened further than its initial amount that it does open.To close it after it opens you need to draw it back to rearm the mechanism.
PCI Express Error
You might try taking the battery completely out for about 60 seconds, and see if this does not reset whatever got hosed. Also, unplug any external devices (like wireless keyboard/mouse, SD card reader, ...) that may be trying to use the PCI buss, just in case something is hosed with them.
How to troubleshoot a non display laptop?
if you can plug in an external monitor and it shows on the external display then either the laptop screen is damaged or you have switched the display to external as default. If nothing shows then it may be a motherboard problem.
