20 Most Recent Toshiba Satellite 1805-S253 Notebook Questions & Answers
Hi
While holding the ESC key, turn the power on.
Do not release this key until a message appears.
Press F1 to enter the System Setup utility
Good Luck
Toshiba... | Answered on Oct 30, 2011
pls check your cdrom data connecter
Toshiba... | Answered on Jan 27, 2011
It sounds as though your system is getting no power at all- try a second ac adapter. If that does not work, if in warranty, contact your technical support provider to get it serviced. If not, there is a good chance you will need a replacement motherboard- find a reputable technician and see about purchasing the replacement board.
I’m happy to help further over the phone at https://www.6ya.com/expert/susan_42b401e0b1603d8a
Toshiba... | Answered on Oct 12, 2010
power supply must b okay but the lead connecting laptop may have gone faulty, try changing it, if this is not the reason then some internal hardware problem
Toshiba... | Answered on Sep 13, 2010
  • Hi, "first," restart the computer, and click on the "Start Button," in the (right pane) select to open the Computer. Check to see if there's a DVD RW Drive (D:) in the "Device: with (Removable Storage) area." If the area is (Blank)? Go to and select All Programs, scroll to find the Media Disk Player. You may need to Setup / Install the player, and "Update the Drivers," when the (install is completed) follow all the instructions. "Remember to always click on the Apply and OK buttons after making the changes, and lastly, restart the computer." "If the problem still exist, try going to the "Device Manager" from the Control Panel, [Roll-back, and or Update Drivers], restart the computer. Next, in a final attempt to fix the problem go back to the (Control Panel), and select from the "Update Options' "Let me Choose... To update the drivers Manually" this will in stall the "original" (Drivers) that came with the computer. "Rating the solution for its helpfulness is appreciated, thanks."
Toshiba... | Answered on May 16, 2010
This is a sign of a driver that really got corrupted , one thing that you can do here is to format and recover the files after doing the format and hopefully those files inside the drive are still intact and not fully damage or corrupted. So format the drive and once done download this software for recovering the files from the formatted drive its called Recuva you can download it from download.com and its for free. Install it to your computer and when you're already trying to recover the files enable the deep scan option.
Toshiba... | Answered on Mar 26, 2010
The Backdoor passwords are not determined by the laptop manufacturer - the backdoor passwords depend on the manufacturer of the bios itself. Is it an Award biosor an AMI bios etc?
Award BIOS backdoor passwords: ALFAROME BIOSTAR KDD ZAAADA ALLy CONCAT Lkwpeter ZBAAACA aLLy CONDO LKWPETER ZJAAADC aLLY Condo PINT 01322222 ALLY d8on pint 589589 aPAf djonet SER 589721 _award HLT SKY_FOX 595595 AWARD_SW J64 SYXZ 598598 AWARD?SW J256 syxz AWARD SW J262 shift + syxz AWARD PW j332 TTPTHA AWKWARD j322 awkward
AMI BIOS Backdoor Passwords: AMI BIOS PASSWORD HEWITT RAND AMI?SW AMI_SW LKWPETER CONDO
Phoenix BIOS Backdoor Passwords: phoenix PHOENIX CMOS BIOS
Misc. Common Passwords ALFAROME BIOSTAR biostar biosstar CMOS cmos LKWPETER lkwpeter setup SETUP Syxz Wodj
Other BIOS Passwords by Manufacturer Manufacturer Password VOBIS & IBM merlin Dell Dell Biostar Biostar Compaq Compaq Enox xo11nE Epox central Freetech Posterie IWill iwill Jetway spooml Packard Bell bell9 QDI QDI Siemens SKY_FOX TMC BIGO Toshiba Toshiba
Toshiba BIOS Most Toshiba laptops and some desktop systems will bypass the BIOS password if the left shift key is held down during boot
Toshiba... | Answered on Nov 05, 2009
Probably a Trident video card. Go into Control Panel>System and select the display adaptor right click and select update driver don't let it contact windows update. Thwe next step should then say this wizard helps you install software for and it will tell you the hardware. Repeat for the audio card.
If that doesn't work right click on the adaptor>Properties>Details>Hardware IDs and google the ven and dev data
Toshiba... | Answered on Oct 10, 2009
for bios password reset u need to plug out the bios cell which is present below ur laptop battery...& then plug it again...
Toshiba... | Answered on Jun 17, 2009
The RAM may need reseating or it maybe faulty.
If reseating the RAM module/s doesn't work and if you have two RAM modules, then try one at a time.
You could take the RAM to your friendly shop and get them tested or test them in another laptop.
Toshiba... | Answered on Jun 01, 2009
Usually this means it supports 512 mb of "Single sided" ram, which is rarer and more expensive... the usual ram you buy now is double-sided.. which will often only see one of the sides in older machines.
Toshiba... | Answered on Mar 14, 2009
the one that connects to your dsl should be Ethernet. Are you sure there is no network port on your PC? the image below shows where this port is. does the dsl fit in here? cf5ca22.jpg
Toshiba... | Answered on Feb 03, 2009
Not sure if you are up to this but if you remove the bios battery for a minute it will reset you may also be able to search for manual for laptop or you may have one
Toshiba... | Answered on Jan 23, 2009
oooh..blue screen too, I'll bet..you may need to boot from install cd, to recover, if you don't have a recovery disk..that is..
Toshiba Satellite 1805-S253 Notebook Logo
Popular Tags
29 questions posted
Top Toshiba Computers & Internet Experts
Ekse
Alun Cox
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
Satellite Toshiba
  • Satellite Toshiba
Most Popular Question
toshiba satellite
  • Computers & Internet
