20 Most Recent Toshiba Satellite Pro A10 Notebook Questions & Answers
Change LCD.
Its not easy to repair that fault.
Toshiba... | Answered on Apr 19, 2015
Basically they don't. They can be purchased and easily installed by opening the cover that contains it and inserting it just like inserting memory and then connecting the white and grey wires to the wireless card.
download the updates from microsoft updates,go to additional files oln the internet and download the files from http://www.microsot.com
Toshiba... | Answered on Nov 27, 2013
You can see if it is in the manuals.
Get online and got to www.google.com In the google search box type: "Toshiba Support" (without the quotes and put your manufacturer name before Support). Look for downloads and drivers. Enter your model number and operating system when requested. Look for Manuals and Documents.
Toshiba... | Answered on Jun 18, 2013
There is no adjustments to tighten the hinges, they need to be replaced.
Replacing a hinge, or both of them, isn't very tough. Check out this WEB site.
http://www.insidemylaptop.com/replace-br...
Toshiba... | Answered on Jul 21, 2012
In network card setting there should be a choice to let windows configure the wireless connection or do you have a protected wireless network?
Toshiba... | Answered on Mar 27, 2012
LOL, what code? If you're talking about the password, which password? The Bios Password, the Hard Drive Password or the Windows User Account Password? Which Operating System? If it's the hard drive password, I'd bet my house you either stole the laptop or bought it hot from someone. If you're not smart enough to remember the password, then you're definitely not smart enough to know how to set a password on the hard drive.
Toshiba... | Answered on Mar 21, 2012
Please visit this site for the solution.
http://uk.computers.toshiba-europe.com/innovation/download_drivers_bios.jsp?service=UK&mode=allMachines&action=search&teddProduct=511&selShortMod=352
Toshiba... | Answered on Mar 24, 2011
mini pci
after that - find a driver for it
Toshiba... | Answered on Feb 25, 2011
hi,
here is what you are going to do.
I have linked below a video from you tube to guide you.
Just view this and give you the steps to do it.
Hope this is useful to you.
Don't forget to rate me. Thanks...
Regards,
John
Toshiba... | Answered on Jan 11, 2011
Usually there is either a slide switch or a key combination like Fn+F2. In case you can't locate it, post me back to ckeck at the manual for you, but please verify your laptop's model.
In case of a problem or clarification, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
Toshiba... | Answered on Sep 25, 2010
You have to go to your Network Places, and click on View Network connections.
Locate the WIreless adapter, right click it and select Enable.
Everything will come back to life.
Good luck
Don't forget to rate this answer if it helps
Toshiba... | Answered on Sep 17, 2010
download the latest soundcard driver for your operating system here-
Install the drivers and restart your machine.
//javaftper
Toshiba... | Answered on Jul 31, 2010
Hi
you need to lift out keypad, one screw under there that holds it in place
gently unclip the clear black panel between the peakers, remove the 3 screws plus metal pate in middle. so easy once you get there, Lol
The silver metal plate that goes over keypad has a screw on RHS that you undo then slide out the ROM
At last, I have helped someone else
emaill me at [email protected]
Toshiba... | Answered on Jun 22, 2010
This information is intended for experienced users. It is not intended for basic users, hackers, or computer thieves. Please do not try any of following procedures if you are not familiar with computer hardware. I'll not be responsible for the use or misuse of this information, including personal injury, loss of data or hardware damage. So use it at your own risk.
A. By Using the Motherboard Jumper:
In most motherboards CMOS battery is soldered, which makes it difficult to remove the battery. In this case we use another method.
Almost all motherboards contain a jumper that can clear all CMOS settings along with the BIOS password. The location of this jumper varies depending upon the motherboard brand. You should read your motherboard manual to check its location. If you don't have the manual then look for the jumpers near the CMOS battery. Most of the manufacturer label the jumper as CLR, CLEAR, CLEAR CMOS, etc.
When you find the jumper, look carefully. There will be 3 pins and the jumper will be joining the center pin to either left or right pin. What you need to do, is remove the jumper and join the center pin to the opposite pin. e.g. if the jumper joins center pin to left pin, then remove it and join center pin to right pin. Now wait for a few seconds and then again remove the jumper and join the center pin to left pin.
Make sure to turn the PC off before opening the cabinet and resetting the jumper.
B. By Using Software:
I have found that BIOS/CMOS Password Recovery Tool is the most effective.:
BIOS/CMOS Password Recovery Tool is a program that works instantly to remove any lost or forgotten BIOS/CMOS password. Simply boot your PC to DOS and execute the program, and get access to forgotten BIOS/CMOS passwords in just seconds
BIOS/CMOS Password Recovery Tool Service: http://www.biospasswordrecovery.com/
Toshiba... | Answered on Jun 08, 2010
Toshiba Satellite Pro A10 Notebook Logo
51 questions posted
Top Toshiba Computers & Internet Experts
Ekse
Alun Cox
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
Satellite Toshiba
  • Satellite Toshiba
Most Popular Question
a10 motherboard schematic diagram
  • Computers & Internet
