20 Most Recent
InFocus LP-LiteShow 802.11b Wireless Adapter Questions & Answers
Windows driver
I believe that this is an incredibly old piece of hardware, so I won't be surprised if there is no more support for it.
You'd be better off getting a new wireless adapter, they sell for as low as a few dollars (TP-Link gives a good bang for the buck).
12/15/2013 9:05:19 PM •
InFocus...
Answered
on Dec 15, 2013
My Infocus in102 image not readable
Please double check that you've focused the lens . and that the screen and the lens are aligned properly. You might have to move the project farther or closer to your screen.
Thank you.
10/16/2022 6:39:04 PM •
InFocus...
Answered
on Oct 16, 2022
How to clean the lens from the inside
you can purchase lens cleaner Cd from market but best way to remove your CD rom cover and clean the lenz manually with lenz cleaner liquid are available in market or just use tissue paper.
12/6/2009 5:52:50 PM •
InFocus...
Answered
on Dec 06, 2009
Projectors cause desktop settings to
Most projectors have a set resolution. If everything gets really big then the projector has a very low resolution. There is nothing that can be done to make it got to a better resolution other than right clicking (windows xp +) the desktop. Goto properties. Then click the settings tab. set the resolution to whatever your projector can support.
If windows gets stuck at a particular resolution (when you plug in another monitor and it is set like it is the projector or vise versa) You should install the monitors drivers and the projectors drivers. These should be avalible on the manufactures site(s). This will cause windows to use the profile of that device instead of the generic "pnp montior" driver. That way it will always know what resolution to set the device to when it is plugged in.
Hope this helps
If you want to know where to get the drivers just google the manufactures name +drivers. Good luck
11/18/2008 6:04:27 PM •
InFocus...
Answered
on Nov 18, 2008
I have an Acer laptop
You need to enable the 2nd video output in the video card settings!
right click on desktop select properties and select the settings tab
Select the monitor 2, click on extend my desktop to this monitor.
Then you can drag windows either out from your main monitor, to up, down, or the sides debends on where you set the 2nd display, you can also change the position of the 2nd screen by draging it around in the middle.
8/19/2008 10:05:15 AM •
InFocus...
Answered
on Aug 19, 2008
I have lost the cd-room
hi friend
if u have the lost the cd then u have download driver from the internet give the model so we can help u batter
thnx useing fixya
7/8/2008 4:51:55 AM •
InFocus...
Answered
on Jul 08, 2008
My Employer Says They Are Going To Cut My Wages. Can They?
If you are in the middle of a contract, then cutting your wages is almost certainly a violation of your employment law rights. While I am by no means an expert on this matter, I did have a similar issue years ago - mid-contract wage cuts - and I hired an
employment attorney to fight the case on my behalf. It turned out that my employer was basically looking to scare people into taking the wage cut.
They got into some pretty serious legal trouble for their transgression, and nothing happened to me in terms of wage cuts after that. If you are between contracts, your employer can re-negotiate your salary, but as far as I am aware, if you are in an agreed-upon contract, they cannot just decide to reduce your salary. If you want to settle matters, contest this action with support from a legal professional.
Solitaire master has a hang
clarify pi please. if you meant pi to mean main screen picture, you probably have used up your free time on this program.
