20 Most Recent
Toshiba Tecra T9000 Notebook Questions & Answers
Some alpabets on toshiba tecra notenook not working
Try getting a can of compressed air and clean out the keyboard. Many times crumbs get in there and get stuck. you can get a can from Walmart, Staples, almost anywhere. Clean it out first. if this fails a key board is easy to instal and you can get a replacement for around $20 or less on ebay.
Wont boot when i put
Your RAM slodge may be malfunctioned.... to solve the problem please check your RAM & RAM slodge... thanks
Sound driver loss
HI
www.toshiba.com
go to support/downloads find your make model and operating system
then go down and find the audio driver
download it
install it
then restart
good luck
Driver sound
b>
Hi.
Click on bellow the link forgo there website
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/home.jsp
And follow the instructionsbellow
b>
SELECT CATEGARRY
SELECT FAMILY
SELECT MODEL
SELECT
OPERATING SYSTEM
SELECT CATAGORIES
DOWNLOAD
FROM THE TITTLE
b>
Now you can download easily one after one. After downloadall the driver, unzip the fie with winrar or zip.
Download the winrar free,
Copy the link and paste on address bar.
http://www.filehippo.com/search?q=winrar
Install it.
Now right click on every downloaded file and select EXTRACRTTO THE FILE FOR......, then create a new folder with the driver file, you caninstall easily.
Hope this helps .
New mouse does not work.
Please check this with another PC to confirm if the mouse itself is defective, if not change the port, reinstall drivers .
Also try to check with another mouse to confirm your system. If so ask for free replacement.
Is the sound card in
the drivers might have been corrupted by something or you might have got a virus run your antivrus program and test for a virus then
you might have to uninstall then reinstall either the sound drivers or the sound card make sure you have both of these devices baked up to a disc before uninstalling
a yellow? question mark means you need to install/update driver right click to install driver
as for the sound
control panel sounds and audio,volume you can adjust the volume or advanced,speakers select appropriate speakers or audio you will find 3 drop down lists make sure you have selected the right speakers or control panel,administrive tools,computer management,device manager scroll to sound,video and game cotrollers could be a yellow question mark? right click to re-install drivers
hope this helps
Unable to connect wirelessly
Hi, lets try to get you connect!
Click the Start button , and then click (“Connect To”). Choose the wireless network from the list that appears, and then click Connect. You will see a confirmation message, when connected to the network. To confirm that you added the computer, do the following: Click to open Network. Important “Always click apply, ok, and restart the computer after making changes to the computer.” "Did this solution help?"
Toshiba tecra problem:
This indicates you may be experiencing a pretty severe hard drive failure. I would recommend replacing your hard drive ASAP, and in the meantime, use your Windows OS disk to repair the windows installation to access your system again. No worries, done properly this process does not erase your files, only your system files that Windows uses to function.
Good Luck
Jesse
Unable to open pages...wireless connection is enabled
Windows WiFi Fix,
Windows Zero Wireless Configuration is one of the best programs to run a WiFi in Windows XP or Vista. Most of the other software packages that come with the different adapters have been poor at best in keeping a connection through Windows. Here is the best guide to get you back up and connected.
Windows XP:
Click Start
Right click on My Computer
When a window pops up click on properties
Click on the Hardware tab
Click Device Manager
Click the [+] next to Network Adapters
Find your wireless card and right click on it.
Click Disable
Windows may warn you that disabling the device may make it stop functioning.
Continue disabling the device.
Wait 30 seconds or so.
Right click on your wireless again and click Enable.
Exit the device manager.
Reconnect to your router.
You should now be able to connect to the internet.
Windows Vista:
Click Start Logo
Right Click Computer
Windows will ask you about opening Device Manager Click Continue
Click Disable
No audio sound on my laptop
Check whether appropriate sound drivers installed in device manager. If installed check if volume is muted in taskbar.
Toshiba t900 will not turn on or charge
Leave the battery disconnected and only hook up the ac adapter. See if you can get the laptop to turn on and get video. If you can then that means either the battery is bad or the charge is so low on the battery it can't turn on the laptop. If the battery is bad then you would have to replace it.
If you still can't get the power on then check the ac adapter to make sure the green light is on. This will let you know the AC Adapter is working properly. if the light is on then the adapter is good, if the green light is not on the adapter then its bad and would need to be replaced.
If after these steps you still can't get power to the laptop then that means the motherboard is bad and would need to be replaced.
