20 Most Recent
IOGear (GCS78) 8-port KVM Switch Questions & Answers
How to daisy chain iogear 8-port miniview
GCS78 can be daisy chained up to 3 levels only.
Let's say you will start with two levels. KVM1 and KVM2.
The ports 1 to 7 of KVM1 should be available for computers, but the port 8 of your GCS78 is for your KVM2.
The port 1 of your KVM2 should be connected to the port 8 of your KVM1. And the rest of the ports of KVM2 should be avail for the computers as well.
Toggling between computers. You need to quickly hit Scroll Lock twice to enable the OSD of your KVM switch. From there, it will give you an option to select which computer you would like to access.
Or you may manually toggle between computer. Here's how:
Scroll Lock twice + port # - Example: Scroll Lock twice + 5 + Enter - The KVM will switch to the computer that is connected to port 5 of KVM1.
If you would like to switch to the computer that is connected to KVM2:
Scroll Lock 2x + 8 (because KVM2 is connected to port 8) + Enter - now the focus of the toggling is in KVM 2. Now, you may hit again Scroll Lock2x + port # + Enter.
You may also refer to the user manual of your KVM for more info. Look for the OSD portion.
Thank you and good luck!
4156 error
go to IOgear web site for firmware if available.
Http microsoft com downloads
Please provide:1-OS o Sistema Operativo2-Did your card comes with a installation CD ?Also remove :it again, turn on turn off on the PC, then put the card again but make sure to clean the plated connectors with at least alcohol and seat gently but hard enough to the card slot.3-Power back the PC and wait until the system recognize the card.4-After if everything goes well check the card driver if is newer than the CD.Post back!
