20 Most Recent
Iomega 2TB StorCenter ix2200 2 x 1TB Questions & Answers
Iomega storcenter ix2-200 hard reset
Please help with this issue.I can access the drives but cannot access the system webpage and configuration. I am using the same ip address as above but page is not loading. the iomega storage manager is also not working even after updating to the latest version. Please help.
12/22/2022 12:44:21 PM •
Iomega 2TB...
Answered
on Dec 22, 2022
Red light is fashing iomega storcenter ix2
I am having the same problem. Once I start the storcenter, blue light start flashing and then in a minute or so it changes to red light. The solutions posted earlier are not clear.
8/4/2013 11:53:21 PM •
Iomega...
Answered
on Aug 04, 2013
Store centre will switch on but wont boot up
It's likely caused by a failing drive. You'll need data recovery help.I would suggest http://FreeDataRecovery.usThey offer both online data recovery and do-it-yourself data recovery services.
9/13/2012 3:40:03 PM •
Iomega...
Answered
on Sep 13, 2012
I'm running OS 10.13.6 on a mac book pro. My Iomega MDHD500-TE is not recognized. What to do?
I suspect that you don't have an Iomega driver in play for use with this Macbook pro that the OS recognizes. There are other possible explanations, you might have a corrupted volume or there might be a problem with the file structure on the Iomega. But if the Iomega was not previously recognized by this MacPro, I think what is missing is a useful driver. You might try one of the driver hunter utilities and see if it finds such for the iomega. If several are found, you would have to try each one at a time and uninstall any that did not work before trying the next, I think.
Here is something else you might try. On the MacPro, on the desktop go into Applications>Utility folder and from the Utilities folder launch the Disk Utility application. If your Iomega is discoverable, it will show up in the left side of the Utility window. If you see it, click on the left side of the window and choose Disk Repair.
If you don't see it in the left side of the Utility window, you may have a corrupted volume preventing it from properly being read on your Mac or there may be a problem with the file structure of the Iomega.
