20 Most Recent Coby 40 TFTV4028 LCD TV Questions & Answers
The only audio output I see is the headphone jack from which to run the sound bar input. Is the sound bar surround/expanded sound features? Check the audio setup menu on Tv, the sound bar input selection, and try a cord from the headphone jack to the sound bar, if you haven't already. There should always be 2 channel stereo at the head jack unless it's turned off in tv menus. I see the owner's manual is very poor.
Coby 40 TFTV4028... | Answered on Oct 27, 2017
Take it back to where you purchased it and get a full refund.
Coby 40 TFTV4028... | Answered on Oct 09, 2017
I'd add something to this. We had the same issue with a 40" coby. We'd declared it dead and after a few days turned it on again to show the problem before trashing it. The TV came on. We've since learned that there seems to be a HDMI handshake issue related to this tv. If you turn it off with HDMI devices still sending a signal, it will periodically return to this point, and take a day before it will turn back on (I guess until the caps are fully drained.) If you turn the TV off first and then devices however, this never seems to happen. Dunno if this is the same for others, but I'm curious
Coby 40 TFTV4028... | Answered on Apr 06, 2016
LCD Panel faulty.
If you wish to get some details; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Coby 40 TFTV4028... | Answered on Apr 02, 2016
Mr. Folk have you took a flashlight when picture goes off and shine in screen and press like menu button and look to see if you can see any letters or anything, if so you probably have a defective screen assy or backlight. This may help?
Coby 40 TFTV4028... | Answered on Feb 09, 2016
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
Faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Coby 40 TFTV4028... | Answered on Jan 04, 2016
Coby lcd tv keeps flickering Flat Panel Televisions ... - Fixya
www.fixya.com > ... > lcd tv keeps flickering > Flat Panel Televisions
Coby flat panel televisions lcd tv keeps flickering related questions and answers. Ask your Coby ... Why does my Coby 40 TFTV4028 LCD TV keeps flickering.
Coby adjust air fuel mixture Flat Panel Televisions ... - Fixya
www.fixya.com > ... > adjust air fuel mixture > Flat Panel Televisions
Coby flat panel televisions adjust air fuel mixture related questions and answers. Ask your Coby ... Coby 32 in tv ... to last channel, and will stop, and will display the first channel it has got. Then we have to make adjustments on channels. ... Ad. Question about 40 TFTV4028 LCD TV. 1 Answer ... Flickering can be adjusted.
Won't turn. on red standby light changes to on but then
Replace the defective power supply that is inside the TV set.
Coby 40 TFTV4028... | Answered on Aug 11, 2015
T'Con board fault. Replace it. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Coby 40 TFTV4028... | Answered on Jul 21, 2015
Contact any service technician. Flickering can be adjusted. But, if there are lines, the T'Con board too have to be replaced.
Coby 40 TFTV4028... | Answered on Jun 06, 2015
If you wish to get some details; visit the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Type in the brand name of your device, in the search box [at the top right] of the display window and the Search will start at once as you type in, and will show you all the related posts. It will make surf easy.
inverter board may be used to power backlight for the lcd display. If it is similar to laptop lcd displays in functionality .
http://www.ehow.com/how_7501465_check-tv-inverter-board.html
Coby 40 TFTV4028... | Answered on May 28, 2015
Unfortunately the failure to mention needs repair by a qualified technician. The solution that is easily accessible by changing the main board , but are now discontinued . I hope I have been helpful . Bye Bye
Coby 40 TFTV4028... | Answered on Apr 02, 2015
If you did not purchase an extended warranty, or if the credit card you used to buy it doesn't extend warranty, I'm afraid you're going to be out of luck. If HH Gregg isn't backing you up , i would not buy anything from them again.
Coby 40 TFTV4028... | Answered on Feb 10, 2015
unfortunately the coby company has gone out of business probably because they have produced an inferior product that has had many, many problems, many people are posting problems with these sets. it is better you just purchase a different brand of tv and leave this heartache causing product behind.
Coby 40 TFTV4028... | Answered on Jan 24, 2015
the coby company has gone out of business probably because they have produced an inferior product that has had many problems, many people are posting problems with these sets. it is better you just purchase a different brand of tv and leave this heartache causing product behind.
Coby 40 TFTV4028 LCD TV Logo
147 questions posted
Top Coby Televison & Video Experts
Steve Allison
Steve Allison
Are you a Coby Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Coby Televison & Video
Most Popular Question
tiny bars running bottom half screen
  • Televison & Video
