20 Most Recent
FUJIFILM S3300 S3350 Digital Camera Questions & Answers
How do I get a date stamp
The date and time (and a lot more) are stored with every picture in its EXIF metadata. Any photo viewing/editing program should be able to display this data. To print this data, please consult the documentation for whatever program you're using to print your pictures. Depending on the program and printer you may print the date on the image, in the margins, or on the back.
I dont have the software to my fujifilm s3300
You don't need any special software.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or, despite what I said first, you can use any photo management program such as Picasa (
http://picasa.google.com ).
I have a fuji finepix
Have you only tried this by setting the mode dial to "A"? Why not try it in "M" for manual? I assume you're following the instructions on pages 28 and 29 of the manual.
I just bought a Fujifilm Finepix HS10 and think that the Aperture doesn't work. When I turn the Aperture ring nothing Happens.
The Fujifilm Finepix HS10 camera features a manual aperture ring on the lens barrel. If you're experiencing issues with the aperture not functioning when you turn the ring, there are a few potential causes and troubleshooting steps you can try:
- Check the camera mode: Ensure that the camera is set to Manual (M) mode or Aperture Priority (A) mode. In these modes, you should have control over the aperture settings. If the camera is in a different mode, switch to M or A mode to enable manual aperture control.
- Enable aperture ring control: Some cameras have a setting that allows you to enable or disable the use of the aperture ring on the lens. Check the camera menu or settings to ensure that the aperture ring control is enabled. If it's disabled, enable it to regain control over the aperture.
- Ensure the lens is properly mounted: Check if the lens is securely mounted to the camera body. If the lens is not properly attached, it may result in the aperture ring not functioning. Remove the lens and then carefully reattach it, ensuring it clicks into place.
- Clean the electrical contacts: Dust or debris on the lens contacts or camera contacts can sometimes interfere with communication between the camera and lens. Use a clean, lint-free cloth to gently wipe the contacts on both the lens and camera body. This can help ensure proper electrical connections.
- Update the camera firmware: Visit the Fujifilm support website and check if there are any firmware updates available for your Finepix HS10 camera. Updating the camera's firmware can address potential bugs or issues that may affect the aperture functionality. Follow the instructions provided by Fujifilm to update the firmware if necessary.
If you have tried these troubleshooting steps and the aperture ring still does not function as expected, it is advisable to contact Fujifilm customer support or take the camera to an authorized service center for further assistance. They will have the expertise to diagnose the specific issue and provide appropriate solutions or repairs if needed.
Fujifilm fine pix camera won't turn on
Old batteries will take a charge, albeit more quickly and cannot supply enough power to carry on working.
Time to purchase a new battery and hope you won't need a new camera as well.
My Fujifilm Finepix S8000FD was unused for a long time and had its batteries leaked, I cleaned it and it says batteries are empty?
It takes 4 x AA batteries. Are the battery contacts on the compartment door, and the battery contacts in the base of the compartment clean and shiny. Usually when batteries leak, they cause oxidization on the metal.
The camera does have very specific requirements.
Batteries are required to operate the digital camera. At
first, load the batteries in the camera.
Compatible batteries
AA-size alkaline batteries (4) or AA-size Ni-MH
rechargeable batteries (4) (sold separately)
CAUTION
• Never use the following types of
batteries, as they could cause
serious problems such as battery
fluid leakage or overheating:
1. Batteries with split or peeling
outer casings
2. Combinations of different
types of batteries or new and used batteries together
• Do not use manganese, Ni-Cd or lithium batteries.
• Use the same brand and grade AA-size alkaline
batteries as those supplied with the camera.
https://www.manualslib.com/manual/54755/Fujifilm-Finepix-S8000fd.html?page=16#manual
And on the next page it shows the polarity two up, and two down. If those weren't correct, you would be on reduced power.
What's the problem and how to fix it fujifilm a100 10 mega pixel digital camera
Without more information about the specific problem you are experiencing with your Fujifilm A100 10 megapixel digital camera, it is difficult to provide a specific troubleshooting solution. Here are a few general tips that may help resolve common issues with digital cameras:
- Check the battery level and replace the batteries if they are low or depleted.
- Check the memory card for any errors or corruption. Try formatting the card or using a different card to see if that resolves the issue.
- Make sure that the camera is not in a mode that is preventing it from functioning properly (e.g., "Movie" mode when trying to take still photos).
- Check the camera lens for any dirt, dust, or debris that could be obstructing the image. Clean the lens with a microfiber cloth or compressed air if necessary.
- Check the camera's firmware version and make sure that it is up to date. If it is not, consider updating the firmware to the latest version.
