20 Most Recent
ViewSonic 27 VX2739wm LCD TV Questions & Answers
Why is my vizio tv's picture black and white?
it could be your flux capacitor is out. you might need to plug it in goto menus and check to see if ur runnin 21 gigawatts if not leave it plugged in and off for two days and it should refresh it
12/29/2022 9:16:23 AM •
ViewSonic...
Answered
on Dec 29, 2022
Tune my viewsonic n3246w tv
First make sure that the current input Source is set to TV to see the option for scanning for channels. There is a Source button on the front of the TV. (It's on the right side as you look at the front of the TV.) The Source button on the original remote is on the left side below the number keys.There are two RF (coaxial) cable inputs near the VGA port on the back of the TV. The digital RF signal needs to go to the port above the VGA port.
To scan for analog channels, press the Menu button. Then navigate to the TV setup option with the Up/Down arrows. Press OK to enter the menu. You can use either the Auto search or the Manual search. However, the Auto will be faster. You can set your country or leave it to Auto. Navigate to Start and press OK for the Auto-scan. There is a DTV menu button above the Volume + button on the remote. Use this menu and look for the Installation section to scan for channels. Again there is an Auto or Manual option.
ManualsLib has the manual for the Viewsonic N3246W here:
https://www.manualslib.com/manual/306714/Viewsonic-N3246w.html. See page 23 for the start of the analog TV channel scan information. See page 30 for the digital TV scan.
I hope this helps.
(For any channel provided by a set-top box, you will not be able to use the TV to store the channel lists.)
4/25/2019 6:17:35 PM •
ViewSonic...
Answered
on Apr 25, 2019
My viewsonic tv its stuck on no media device how do i fix it without a remote
Do a reset to this TV, and then check. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts.
https://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done./
5/30/2018 12:34:39 PM •
ViewSonic...
Answered
on May 30, 2018
