To find a replacement band for your Adidas Fortitude watch model ADP1709, you can check with the manufacturer or an authorized dealer for the specific model. You can also look for compatible replacement bands from third-party retailers or online marketplaces, making sure to verify the fit and quality before making a purchase.
If your Adidas Archive M1 watch is "blocked," it is likely that the watch's movement has stopped working properly. This can happen for a variety of reasons such as a dead battery, a malfunctioning quartz crystal, or a problem with the gears or other internal components.
To fix this issue, it is best to take the watch to a qualified watch repair professional who can diagnose and repair the problem. They can determine if the problem is a minor one that can be fixed quickly or if a more extensive repair is needed. Additionally, you can try the following steps:
Check the battery: If the watch has a battery, make sure it is still good and replace it if necessary.
Check the crown: Make sure the crown (the knob on the side of the watch) is not in the "pulled out" position. If it is, push it back in.
Check the time: If the watch has stopped working, try resetting the time and see if that fixes the problem.
It's also a good idea to refer to the manufacturer's manual for troubleshooting steps and warranty information, as some issues may be covered under the warranty.
This has already been posted on Fixya, so I take no credit for it. I've put the original reply below :-
Directions for setting the time on the adidas duramo / furano / uraha / paruko watch 1. press and hold the SET/LIGHT button (upper left) until "light on" or "light off" is displayed 2. press the MODE button (lower left) until "hour" is displayed and the hour digits are flashing 3. use the START/STOP (upper right) button to increase the hour, and use the LAP/RESET (lower right) button to decrease the hour 4. press the MODE (lower left) button again and "minute" is displayed and the minute digits are flashing 5. use the START/STOP (upper right) button to increase the minute, and use the LAP/RESET (lower right) button to decrease the minute 6. press the MODE (lower left) button again and "second" is displayed and the second digits are flashing 7. use the START/STOP (upper right) button or the LAP/RESET (lower right) button to set the seconds to "00" 8. press the SET/LIGHT (upper left) button to accept the changes
