20 Most Recent Logitech X-530 5.1 Channel Speaker System Computer Speakers Questions & Answers
My Logitech X-530 5.1 Speaker
Sorry they do not repair these except under basic warranty and even then you get an exchange system.
6/29/2017 7:55:30 PM • Logitech X-530... • Answered on Jun 29, 2017
2answers
Blown fuse in Subwoofer unit, what amperage to
usually it is 0.5 amps. if it still blows, you might have a shorted board.
10/30/2013 11:50:04 AM • Logitech X-530... • Answered on Oct 30, 2013
I am running Windows 7 on an Intel I5-750
try the 7.1 home theartre configuration or 7.1wide cofiguration speakers in the sound settings
7/27/2010 12:34:46 AM • Logitech X-530... • Answered on Jul 27, 2010
HOW TO HOOK UP ALL MY X-530 LOGITECH SPEAKER ON MY
You'll only be able to get true surround sound utilizing all the speakers if you have a sound card with multiple outputs (usually color coded as Green, Black, and Orange). Plug the satellite speakers into the subwoofer and run the three input wires (Green, Black, Orange) to your multi-source output.
If you only have one output on your PC (common), you should just connect the green wire and press the "matrix" button on the system. This will just duplicate the sound output into the other channels but is not "real" surround sound.
Hope that helps.
2/7/2010 7:16:44 PM • Logitech X-530... • Answered on Feb 07, 2010
Can't figure out how to set the speakers up to the
just remember look to the color of the cable.. usually the color of the cable match to the outlet on the tv..
8/25/2009 10:56:39 PM • Logitech X-530... • Answered on Aug 25, 2009
X-530 one speaker not working
this is a problem that i have faced as well it is likely that the cable going in to the jack could be loose and you might need to move it a bit, but in your case i think most likely would be that the input jack on the sub for the speaker is broken in that case you should call up logitech and ask technical support to see what they can do for you should be covered by warranty!
2/11/2009 11:52:59 AM • Logitech X-530... • Answered on Feb 11, 2009
I just bought new speakers
Sorry just doublechecked your board specs. Go to the sound properties in control panel. Click on the configure speakers option. If everything is plugged in right then windows should configure it for you to a 5.1 config. Hope this helps.
12/27/2008 1:04:27 AM • Logitech X-530... • Answered on Dec 27, 2008
Connecting dvd player to logitech x-530
Well, if you have a DVD-ROM, all you need is a video card with a s-video out to connect to your TV and then you could put your DVD player in your room and play your DVD's from your PC. Another way to do it (without having to buy anything) is to connect the sound of your DVD player to a stereo receiver and then plug the sub into the headphone jacks and the speakers to the sub.
3/26/2007 11:31:01 PM • Logitech X-530... • Answered on Mar 26, 2007
Volume control on the master speaker
If its a rotory type control simply take the rest out or off the pcb if you can and on the side of almost any varable resistor or pot is a value. Look to see if radio shack has that value or check your local electronic parts supply house and solder back into place But you may not get the exact one as they all have differant mechanical standards as the shaft may be too long or it may not fit on the pcb so you will have to drill into the cabinet and mount where theres nothing in the way and hook the wires to the control from where the old control was. Hope this helps good luck
3/18/2007 2:41:19 AM • Logitech X-530... • Answered on Mar 18, 2007
Can I get a replacement controller c/w 2.0 speakers for a Logitech Z3 S-0085B? Or something similar that would be compatible?
fixya doesnt sell or manufacturer products -notify manufacturer --electronic shop or online search for assistance
8/31/2023 3:08:11 PM • Logitech Audio... • Answered on Aug 31, 2023
I have the logitech docking speaker s-0329A how can i get my iphone 4 to work on it as when i put it on it says it does not support it and can i use an android phone on it through the headphone jack?
The Aux connection should work for either an iphone or android phone. That would be a good test to see if the speaker is still working. The top mounted iphone/ipod connecter can collect dirt and lint that will cause the proper connections to be made. Try cleaning these.
3/12/2023 5:39:30 PM • Logitech Audio... • Answered on Mar 12, 2023
Logitech x-540 speakers worked great with my old laptop but now I have an ASUS laptop and the light comes on on the volume controller but I get no sound and everything is hooked up correctly
Here's a link to the manual. https://www.logitech.com/assets/35723/setup-installation-guide.pdf This is important: 3. A. If you have a PC and a: • 6, 7 or 8 channel (5.1, 6.1 or 7.1) sound card: Connect all 3 colored plugs from the audio input cable to the color-coded jacks on the sound card. 1. If jacks on your soundcard are not color coded, plug the audio input as follows: • green to front L/R (or #1) • black to rear L/R (or #2) • orange to center / sub (or #3) • 4-channel sound card: Connect the green plug from the audio input cable to your sound card's front jack and the black plug to your sound card's rear jack. Do not use the orange plug. • 2-channel sound card: Connect the green plug from the audio input cable to the "line out" jack on your sound card. Do not use the black or orange plugs.
3/12/2023 5:30:36 PM • Logitech Audio... • Answered on Mar 12, 2023
How can we dismantle Logitech Laptop Speaker Z205?
If you try to open these speakers they will never work properly again. There are no screws. All the joints are stapled and glued.
3/12/2023 5:23:28 PM • Logitech Audio... • Answered on Mar 12, 2023
Logitech X-530 5.1 Channel Speaker System Computer Speakers Logo
Popular Tags
22 questions posted
Top Logitech Audio Players & Recorders Experts
Paul Bade
 Grubhead
Grubhead
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Logitech Audio Players & Recorders
Most Popular Question
x 530 one speaker not working
  • Audio Players & Recorders
