20 Most Recent
Logitech X-220 Computer Speakers Questions & Answers
I dont have any sound, I got a message bottom
You don't need a driver for the speakers, but a driver for the sound card installed inside your computer. If the computer came with that sound card then you can find the proper driver from the manyfacturer website -> Support section.
Sound drivers need to be reinstalled sometimes after iTunes updates or video game installs.
X-220 cable is slightly damaged
nothing is wrong with the woofer the connect is broken at the strain relief and the cable needs to be replaced.
You can replace the connector if you know the pinouts. You will need the connector and the schematic.
you may be able to find the pin outs configuration here.
http://pinouts.ru/
As for the connector this may take a search online.
Logitech X-220 Cant open
This model can be open by the front ... just remove the fabric cover gently with a flat sreew driver and you will see de removal screew. :-)
Speakers quit producing sound
Likely the speakers are broken.
The usual issue is that the cable is broken inside the speaker. This is not repairable.
I have installed windows 7
click start control panel hardware and sound manage audio devices playaback you should see your speakers right click select enable or you might have to configure them this option will be at the bottom of of the playback list windows7
hope this helps
