You may have to call Logitech support or email to find out what the pin out is. that would be my only solution if there ...
you have to reload the machine and if it continues like that,you have to buy a sound blaster
are you getting any sound at all from them? -d
Need a Sound Card for 7.1 audio channels
Hi bud , Happy new year ...Have you made sure you installed all your drivers on your new PC for your soundcard , also ...
other tha a 3 way speaker adapter you need to get a 5.1 surround sound card
check te switch wether its work...... or check your connection 15pin all the pins are in place if that okay its need to ...
The Logitech website under the support section. All you need to do is look up your model # and then download the ...
Connect the DSL Modem to Router in the port named Modem (usually yellow in color) using an Ethernet cable. Connect the ... written by Belkin_tech
Check the Speaker Connections and Volume Control Settings Step 1 Verify that the lack of sound is not due to faulty ... written by callonafo
If your sound does not work and the little speaker icon by your clock does not appear and your computer says no sound ... written by joebuty420
how to connect the wires of a logitech z-640 to my tv
My Legitech Z-640 speakers arent working properly. noise is only going through the two rear speakers. It seams to be the ...
sub woofer wont work and i am pretty sure the aux (green, black and orange) are in the right holes of my HP Media Center ...
My Logitech a-640 speaker is popping, can I get it repaired?
recently purchased a used logitech Z-640 sub w/ 2 satellite speakers...i cannot seem to find the center speaker,which ...
Cynthia would like to know what tiny speakers are compatible with the Z640 boom box. I don't need 6-8 speakers just ...
sub and rear speakers work, centre and front speakers don't. Logitech X-640
Is there a place i can download the installation disk? I had to bring my computer back to factory settings and i do not ...
More than 2 million solutions and counting...
