20 Most Recent
Canon EOS 1100D / Rebel T3 Digital Camera Questions & Answers
Auto focus
Have you checked the lens to see if auto focus is turned on? Sometimes the switch can get accidentally turned to the manual focus position.
Canon T3 flash flutters and does not take pictures help!
The 'fluttering' is a pre flash used to help the camera focus in low light. The internal flash isn't a powerful flash and is usually only good enough for subjects up to about 2m away in reasonable light also to light a subject that is back lit. Try putting the camera in manual mode (M) 1/60sec on f5.6 flash popped up review it and make adjustments accordingly i.e. open up or shut down the aperture as the flash usually syncs at 1/60
Why would my Auto focus mirror not folding up completely.
The mirror is designed to fully swing from top to bottom with out any interference unless something was jammed inside. If you are shooting with the lens off and watching the mirror only partially open something is jammed and needs repair. To test this put the camera in Manual mode ( M on the mode selector dial) Set the shutter speed to 1/4 of a second and press the shutter button. Having a slow shutter will allow you to see if it is fully opening and closing.
If you are making this assumption based on seeing images that have only a portion of the frame exposed, then the most likely scenario is you are taking pictures with the flash on at a shutter speed greater than 1/250 of a second. This causes the flash to fire before the shutter is fully open and therefore only part of the frame is exposed. Google "Shutter Sync Speed".
Good Luck
No power
Did you change battery or charge battery fully for 2 or 3 hours. Rich
How to fix error 20 on 1100D canon camera
U have to fix this by the way of getting new button. U can get it on ebay or aliexpressm, etc. Disassemle the front side and button section, get out old button, than put new button and settle it down with trigger. And that is all! Good luck!
T3 built in flash won't pop up. Says I have an external flash attached, but I don't.
There is a small flat leaf spring under the hot shoe rail where an eternal flash slides in. If an external flash is mounted the leaf spring is pressed against a small button telling the camera that there is an external flash mounted. Take a toothpick and rub under the hot shoe rail gently to more the leaf spring or unjam the leaf spring. You may even see the button depressed, poke at it a time or two with a toothpick, even a drop of rubbing alcohol may unstick this button if a sticky beverage sprayed on it.
