Xerox DocuColor 1632 Laser Printer
Problems with Xerox DocuColor 1632 Laser Printer?
Ask our Experts
Chat with a Pro
Tell us why
Share your Experience
Do you recommend the
Troubleshooting and Support
Solved Problems for Xerox DocuColor 1632 Laser Printer RSS Feed
Click here to get instant support from our best Experts!
View More Results for Xerox DocuColor 1632 Laser Printer
Questions and Unsolved Support Problems
Unsolved Problems for Xerox DocuColor 1632 Laser Printer RSS Feed
Answer
error code 007-115is one of the codes, Printer only goes into scan mode.
Answer
xerox docucolor 1632 displays 006-382 and 004-347 fault codes
Answer
xerox docucolor 1632 displays fault codes 006-382 or 004-347. it also displays:a fault has occurred,... (More)
Answer
xerox docucolor 1632 displays fault code 004-347 or 006-382
Answer
please can anybody help me; how can i change screen language on xerox docucolour 2240? from german... (More)
Answer
how Do I Enter the Diagnostics Mode and clear error
Find a Manual
Xerox DocuColor 1632 Laser Printer Manuals & Guides
WikiManual
(Post a New Chapter)
Inkjets and Laser Priners, Inks, Toners,...
Using recycled ink cartridges in your ink-jet printer is never a more economical way to do colour printing, unless you are willing to become a master... by Soulvisitor
How to Refill and Reuse a Printer Cartridge
Printer ink is one of the most expensive things that you'll run into when you set up your home office. You start out taking dozens of pictures with... by wikihow
How to Cut Printing Costs on Inkjet Color Printer
With all of the color printing that people do nowadays, its hard to find ways to print inexpensively. There are ways to reduce printing costs on... by wikihow
How to Check if Your Printer Has Run out of Ink
Have you ever wondered if your printer has run out of a colour? Here's a simple way to check. Steps: 1. Go into Microsoft Word. 2. Create four small... by wikihow
Lexmark All-in-One x3350
'Resetting' your Lexmark x3350 All-in-One So I tried using my Lexmark today... the power button is constantly on, and it won't do anything, My... by TTonyTigger
Upload Manuals
Tips & How To Guides for the Xerox DocuColor 1632 Laser Printer
Earn cash by writing Tips & How-To's.
It's easy!  (Learn more)
Black lines on faxes or copies
Do you have black lines in your scanned or copied documents? The typical problem is ink, correction fluid or trash blocking the image sensor. Look at... written by buddymc
How can I print what appears on the screen completely?
Many web designers are conscious of the fact that some people will want hard copies of their web pages. For these sites, you can... written by mianaftab
Printers and scanners and copiers (OH MY!)
How do I fix the error on my printer scanner copier fax that says "yada yada yada you cant print anymore"? 99% of the time, you cant. You... written by fredtmccoyjr
Setting up Epson Stylus SX515w on a PC.
This guide will show you how to setup the Epson Stylus SX515w, without using the setup CD & USB cable. 1) Using the Control... written by TJ4722
how to get rid off paper jam errors in lexmark injet printers .
1. Turn the printer off and open the access cover. 2. Look for any obstructions in the paper path and remove them if necessary. (It is possible to... written by Ajkill
How to maintain your ink-jet printer
In the printer market there have thousands difference brands and models ink-jet and laser-jet printer, how can we eleminate their trouble to the... written by swan34
How to reset drum message after replacement on brother printers
Does your brother printer or fax machine have bad printing such as dark blurry pages or your machines says replace drum then follow these... written by buddymc
How to clean the corona wire on Intellafax 2800,2810, 3800 machines
Does your brother printer or fax machine have bad printing such as very light print or spotty print. If you have these problems chances are you have a... written by buddymc
I need help with
near zipcode:
Please enter your zipcode
Search
Top Repair Providers for Xerox DocuColor 1632 Laser Printer
Nationwide | 8008369287 | Website
Celebrating 14 Years Of Outstanding Printer Repair And... Read More
Featured Listing
Nationwide | 972-907-9771 | Website
Printronix, IBM, Tally, Genicom, TallyGenicom, Dig... Read More
Featured Listing
Nationwide | 9185835483 | Website
Elite printer Services, Inc. is a full service HP & L... Read More
Featured Listing
Nationwide | 800-786-0288 | Website
Accram is now one of the largest nation wide mai... Read More
Ratings for the
Find a Warranty
Specifications for Xerox DocuColor 1632 Laser Printer
Key Features
Technology (Detailed)
Laser
Max Resolution (Color)
1200 x 1200 dpi
Black Print Speed
32 ppm
Max Resolution (BW)
1200 x 1200 dpi
Color Print Speed
16 ppm
Technical Features
Connectivity Technology
Cable
Duplex Printout
Standard
Language Simulation
PCL 5E
Media
Media Type
Transparencies · Plain Paper
Total Media Capacity
3140 Sheets
System Requirements
Operating System
Microsoft Windows 95
Dimensions
Depth
30.7 in.
Xerox Contact Information
Main support number1-800-821-2797
Describe your problem:
Top Printer Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
