20 Most Recent Hifonics HFI1500D 1Channel Car Amp Questions & Answers
MKe sure you have 12 vole coming from m your remote will re after your system starts up.
Hifonics Car... | Answered on Dec 03, 2017
By your description allegedly 2 x 100watt. So 200w music power.
Hifonics Car... | Answered on Nov 19, 2017
Run a dual 2ohm sub on it. Bridged parallel. That will give you your max. 600rms/1200max
I’m happy to help further over the phone at https://www.6ya.com/expert/chris_7f7f91eb941fb23f
Hifonics Car... | Answered on Oct 04, 2017
There is nada wrong with your preamp and changing it will accomplish nothing. If your channels are allegedly clipping it is due to the fact that it is being over driven. A bad preamp could not over drive your amp!
Have to be careful with tone controls at high levels. Every 3db increase compels amp to double power at that frequency. So if you are blasting at 2000 watts and you boost a control by that amount, your amp will put out 4000 watts and clip. If plus 6db then it is 8000 watts!
Hifonics Car... | Answered on Jun 20, 2017
Overdriving the output can cause it to go into protect mode. You will not be able to restore normal operation until failed components are replaced.
Hifonics Car... | Answered on Jun 06, 2017
Some amps will not power up internally if u donot have remote wire. Also if u connect power then remote wire it will not power up until u reconnect in correct order. But if all that is ok. Than u have a bad amp
Hifonics Car... | Answered on Mar 11, 2017
Your amplifier may have experienced circuit failure other than a dead short that still allows power to be applied
Hifonics Car... | Answered on Dec 05, 2016
That will require an amplifier and enclosure, as well as "audio out" connector(s) on your TV or set-top box.
Hifonics Car... | Answered on Sep 20, 2016
Did you check out manufacturer website?
Hifonics Car... | Answered on Apr 01, 2016
Speaker wiring or the speaker is loading the output transistors to a point where the protection mode kicks in.
Hifonics Car... | Answered on Dec 17, 2015
Hifonics HFI1500D 1Channel Car Amp Logo
Popular Tags
0 questions posted
Top Hifonics Car Audio & Video Experts
Steve Sweetleaf
Steve Sweetleaf
Jaime Hernandez
Marvin
Marvin
Are you a Hifonics Car Audio and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Hifonics Car Audio & Video
Most Popular Question
need know pot used level control 20k
  • Car Audio & Video
