20 Most Recent
Microsoft Windows 7 Ultimate Upgrade OEM 64Bit Questions & Answers
Error 50050008 Windows Updates
click start type cmd press enter then type in chkdsk/f/r which will scan for and and attempt repair of bad files and bad sectors on hard drive
you should have no input while chkdsk utility is in progress any input might further damage your computer or
Use the System File Checker tool (SFC.exe) to determine which file is causing the issue and then replace the file.
Type the following command and then press ENTER: sfc /scannow The sfc /scannow command scans all protected system files and replaces incorrect versions with correct Microsoft versions.
hope this helps
4/29/2014 8:35:58 AM •
Microsoft...
Answered
on Apr 29, 2014
Windows updates doesn't work
hope this helps
10/3/2012 6:36:30 AM •
Microsoft...
Answered
on Oct 03, 2012
What is the 500 connect failed?
Good morning Jenna,
Majority of the time, a 500 connect fail error is associated with a HTTP Error 500 Internal server error. I am not sure if this is what you are referring to, if not, do let me know and I will address it accordingly.
So, what is an error that is presented when the Web Server (the program running the Web Site you are trying to enter) encounters to renders an unexpected problem that prevented it from fulfilling the request by the client (yourself via your web browser i.e. Google Chrome, Internet Explorer and the like).
If this is the problem you are having when you attempt to access a website, then there is nothing you can do unless you own the website and have access to the software running it.
I hope this helps,
Cheers,
MarkyyG123
Windows Anytime Upgrade User Interface Has Stopped Working
windows 7 cannot be updated to another type of windows 7 without purchasing a new *********** for that version and then downloading updates.
Option2, reinstalling windows using an ultimate disc rather than a basic disk.
If you have a key for ultimate you would change your *********** and then manually start update service.
Change language for packard bell
You must have Ultimate or Enterprise edition to go from Polish to English, otherwise you must buy an English version of Windows 7 and re-install the Operating System.
- Start -> All Programs --> Windows Update --> Optional Updates.
- Open optional Updates and go to the section Windows 7 Language Packs.
- Tick the Language Pack you want and hit OK
- Proceed with Install Updates
- Depiction of Windows 7 downloading a Language Pack
- Automatic install initiated after download
How to change the Windows 7 Display Language:
- Go to Start -> Control Panel -> Clock, Language, and Region / Change the display language
- Switch the display language in the Choose a display language dropdown menu.
- Click OK
- Log off for the changes to take effect (This will affect only the user profile under which you are currently logged on).
Windows 7 activation code
Windows 7 product activation code is on the cover of the package of windows 7 its a bunch of characters and numbers in 4 sets of 5 example ( J7PYM-6X6FJ-QRKYT-TW4KF-BY7H9) this is just an example of what to look for dont try to use this it wont work. you get to use the code one time only.
Cannot review detail on backup xx.v21 files is this possible?
That looks like an obsolete file format. Did you do the backup with "Ghost"? If you can get Ghost 2009 or later, because it has backward compatibility you'll be able to access those .v21 (or .v2i) backups. The software has been taken over by different companies (Symantec, Norton, etc) so try their websites to see if they offer a free utility for .v21 conversion.
How do I delete YouTube?
Go to panel control > add/remove programs and see if there's any program on the list with that name. If there's not, you have not installed any program with that name.
How do I open locked files?
Please clarify your question. I am not sure if these files were locked using a third party software or they were encrypted using WINDOWS 7 ntfs permissions
