20 Most Recent Xerox Phaser 8500N Printer Questions & Answers
Am using Phaser 8860 its a good printer but the problem am facing is that it is failing to clean the head or drum. The first testing page gets stuck on the head or drum. The drum is always dirt with colours of the first page. Kindly heal
Xerox Phaser... | Answered on Nov 09, 2013
From the service manual:
37,002.4x - PEST_FAULT_JSL_HEATER_DISCONNECT
PEST - Left jetstack disconnect.The left jetstack is not drawing the expected power from
the supply.
1. Run the printhead Left Jetstack Heater test.
2. Verify printhead wiring.
Yes, could be faulty printhead, but could be faulty power supply as well.
I have the full service manual available if you need it. Please take a moment to give this solution a rating of fixya. Thanks!
Xerox Phaser... | Answered on Sep 06, 2012
You can't. Just simply stated. It is the way it's designed.
Per Xerox below
NOTE: The automatic printhead cleaning cycle cannot be disabled.
The printer performs automatic printhead cleaning cycles to remove air bubbles or foreign matter that can cause a printhead jet to malfunction. An automatic printhead cleaning cycle is performed when the printer is first powered ON, or if the ink has cooled to the point that a cleaning cycle is required.
Powering OFF the printer longer than 3 or 4 minutes will also cause the printer to perform a printhead cleaning cycle when the printer is powered back ON, which uses ink. To minimize ink consumption, keep the printer powered ON at all times.
Xerox Phaser... | Answered on May 09, 2011
The phaser printer using the wax cartridges requires cleaning every so often.
Load standard 8.5x 11 paper and go into the maintenence area on the front panel of the printer. There are 3 types of cleaning available. Use the deep clean option and the printer will spit out several sheets of paper. (THROW THESE AWAY) Don't atempt to reuse the cleaning sheets as it has caused problems for me in the past.
Once done reset the printer.
Good Luck
Xerox Phaser... | Answered on Jan 25, 2011
Your machine has a problem counting the yellow ink sticks, this can be caused by non Xerox ink or faulty/broken Xerox inks.
Your machine has now gone into a flagged fault state and needs to have the flag reset.
In order to reset the flag, you need to go into 'Troubleshooting' then into 'Service Tools'. Once in service tools press and hold the up button, then press the down button. This will take you into a hidden service menu. Scroll down this menu and look for 'Clear ISC fault' or 'Reset Ink Loader' (there will only be one or the other not both commands) highlight the command by scrolling down to it. Press the OK button, nothing will happen. (Press a couple of times if you want to be sure). Now scroll down to exit and select to return to the previous menu. Switch the printer off by the off switch on the side of the printer, NOT at the wall/plug socket.
Your printer will now reboot. Please be aware, if there is a faulty switch on the ink loader, this method will work until 2.5 inks have gone through the machine, it will then give you the fault again. If it was just a dodgy ink stick, this will be a permanent solution.
Hope it helps you.
Xerox Phaser... | Answered on Jan 19, 2011
This fault code is saying that the printhead reservoir thermistor circuit is open. Unfortunately, only a printhead replacement will solve this problem.
Here is the Xerox definitive answer: 8,035.42 The media path motor stalled while moving the cap/wipe UP.
  • Check for paper in the paper path.
  • Check the condition of the Pick and ****** Rollers
  • Is the machine extra noisy? Are you able to get the cover off the right-hand side and check that the gearbox is still securly fixed to the machine (the posts that hold this on can become weak and snap).
    Xerox Phaser... | Answered on Jan 18, 2011
    There is a problem with the power up of the printer. For 37,00x.xx error codes you can try power off the printer, wait 30 seconds and power it back on. According to the Xerox support website for 37,008:44 error code you should Verify the Printer's power source and isolate the printer.
    Xerox Phaser... | Answered on Dec 26, 2010
    Hello, and thanks for using FixYa.
    There seems to be a communication problem between the printer and the pc. I'd recommend that you uninstall the printer from the commputer, you can do so from start -> control panel -> uninstall programs or "add or remove" programs.
    After you have removed the printers software, if any exists. Then go to the printers and faxes folder. Which you will find from either start menu or from start -> control panel -> or in some cases it might also be in My computer.
    Once inside the folder, right click on your printer and select delete. Also disconnect the printers usb canble and make sure there are no other printers with the same name installed there.
    Now restart the computer, and being to install the printer back to the computer like you did when you purchased it. Insert the cd and run the setup. if you no longer have the disc you may obtain the software from http://www.support.xerox.com/go/results.asp?Xtype=download&prodID=8500_8550&Xlang=en_US&Xcntry=USA
    after you have installed the printer it should work normally again.
    Please let me know if you require further assistance or if you have any questions.
    Thanks,
    Ekse
    Xerox Phaser... | Answered on Oct 15, 2010
    You most likely need to replace the ink loader. It is not hard to do at all.
    I dont have that sprcific documentation. But if you call 1-800-835-6100 and follow the prompts to parts, they can find the correct part number and quote you a price. If you want after that. let me know I can write you directions on how to replace it. If you have a maintenance agreement they will replace it and it will not be extra. But it is not difficult at all to replace.
    Xerox Phaser... | Answered on Jul 09, 2010
    37,018.45: Head Maintenance Clutch Disconnect. The Head Maintenance Clutch is not drawing the expected power from the supply.
    You'll probably need service.
    Xerox Phaser... | Answered on Jun 30, 2010
    The configuration card is for the wrong product.
    1. Turn off the printer
    2. Verify that the Configuration card is the correct type for the printer
    (located at the rear of the printer.)
    3. Insert or replace the card
    4. Turn on the printer.
    5. If the problem persists, replace the main electronics module.
    Xerox Phaser... | Answered on May 28, 2010
    Xerox Phaser 8500N Printer Logo
    51 questions posted
    Top Xerox Office Equipment & Supplies Experts
    Clive
    Clive
    Philip Hughes
    docukaaf
    Level 1 Expert
    Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
    View Most Popular
    Phaser Xerox
    • Phaser Xerox
    Most Popular Question
    xerox 8500 printer fault 37 002 47 29330
    • Office Equipment & Supplies
