20 Most Recent Yamaha Aw2400 Aw 2400 Digital Workstation Questions & Answers
I do not know what you mean by 'resetting'.
Here's the manual:
https://usa.yamaha.com/files/download/other_assets/9/335089/aw2400_en_om_b0.pdf
Yamaha Aw2400 Aw... | Answered on Dec 24, 2017
Here is an online manual for it. Can't find a download.
http://music.manualsonline.com/manuals/mfg/yamaha/aw2400.html?idRes=12818647
Yamaha Aw2400 Aw... | Answered on Mar 06, 2013
Unless you are a tech, trained to repair this type of gear, I would strongly advise you to have it repaired by such a tech. Don't risk damaging the keyboard beyond repair. Spend the money.
Yamaha Music | Answered on Dec 03, 2018
either plug connection or headphones plug damaged or shorted
Yamaha Music | Answered on Nov 26, 2018
Hi, The trigger below the pad is a ceramic disc. The wire soldered to it may have come loose/broken. Try resoldering it, else you can replace it.
Yamaha Music | Answered on Nov 21, 2018
Yamaha would be a possible source.
Yamaha Music | Answered on Nov 19, 2018
Google can be a miracle for finding manuals. Type in specifically what you need!
Yamaha Music | Answered on Nov 08, 2018
You can use the Line In jack, but you will probably need to use a mic preamp to raise the mic output sufficiently. You can try using an inexpensive mic from an amateur karaoke system or Guitar Hero etc. If that mic has no 1/8 inch mini phone plug, you can look for an adaptor, or have a tech type person set the mic cable up for you. If you want better quality, borrow or buy a professional vocal mic which uses an XLR cable and adapt the cable to plug into the 1/8 inch Line In jack on the keyboard. As I said, if the mic level is not loud enough, you can use a mic preamp, such as the ART Tube Mic Pre, which you can find used, or on a clear-out for maybe $25 to $35. Use a cable with a 1/4 inch connector on one end and a 1/8 inch connector on the other, to connect the mic pre output to the keyboard Line in. Plug the mic into the XLR input of the mic preamp. This will work 100%. Just adjust the mic preamp level controls carefully.
Yamaha Music | Answered on Nov 03, 2018
Yamaha has the user's guides available as PDFs for most of their instruments on their site: http://download.yamaha.com/top/?site=usa.yamaha.com&language=en . Enter PSR-6000 or select Pianos & Keyboards > Portable Keyboards > PSR-6000 and then press Select.
The link to the manual will display below the search area.
I hope this helps.
Is there a pattern to the wrong notes ( eg all up a semitone ? )
If so you could have altered the tuning.
Try a master reset:
Hold down top key whilst turning on. This will reset to factory setup.
See attached for individual reset procedures:
Yamaha Aw2400 Aw 2400 Digital Workstation Logo
4 questions posted
Top Yamaha Music Experts
Mike
Are you a Yamaha Music Expert? Answer questions, earn points and help others
View Most Popular
Yamaha Music
  • Yamaha Music
Most Popular Question
howto reset yamaha aw2400
  • Music
