Marconi Systems 13 ft. Fiber Optic Network Cable
Problems with Marconi Systems 13 ft. Fiber Optic Network Cable?
Troubleshooting and Support
Solved Problems for Marconi Systems 13 ft. Fiber Optic Network Cable RSS Feed Post a New Problem
gps cable receiver
The connector for my tom tom cable receiver has pulled off the cable.. I need to replace it with a new one if possible...
1 Solution
Normal RS -232 cable
Hi I want to know RS-232 cable pin connections EX- pin 1 to 1 connector specification pls send to me
1 Solution
vlan
dear sir, i want to know detailed about VLAN. what is is? and how it work.is it possible on switch only or router...
1 Solution
change ethernet cable
please tell me how to change the end of ethernet cable, the little piece broken. I have the cutting tool and the clear...
1 Solution
difrence of lan wan
lan limit is 40 to 60km then 61km is wan
1 Solution
how to run cat5 for phone wire
i'm going with cox cable company for service {phone ,cable, and net] how do i run cat5 in the house .do i start from...
1 Solution
Single-line data transfer
Can I make R45 cable for transmit/sent only?
1 Solution
Tips & Tricks
Post a New Tip
WikiManual
Post a New Chapter
Manuals & Guides
Post your Manual or Guide
Specifications
Key Features
Package Qty.1
Cable FunctionCable
Cable TypeNetwork
Length13.12 ft.
TechnologyFiber Optic
Connectors
Left Connector TypeMT-RJ
Left GenderMale
Right Connector TypeSC
Right GenderMale
Supported Models
MTRJ-SC/MM, MTRJ-SC/SM
Marconi Systems Contact Information
Main support number1-877-777-7441
Support FAX1-972-669-6388
Sponsored Links
Loading problems.
Top Experts
Ask Me
cdhardy Wiz
1 solutions
Ask Me
manjuvasu Guide
1 solutions
Ask Me
STP162 Guru
1 solutions
Repair Service
Find Network Cable Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
