can you help me with drivers for this printer, nc400 is the only driver at fuji but it doesn't play in windows well...
printpix nc-1000
1 Solution
service code
i need the service code for the fuji ic-1000 station
1 Solution
paper supply tray
I can't pull the paper supply tray out
2 Solutions
user manual
where can i found a user manual for the printpix nc-1000 and the ic-1000 station
1 Solution
fuji printpix nc 1000
I have fuji print pix nc 1000 but no controler, how I can do to connect to regulaire computer?
1 Solution
printpix 1000
Where do I get paper refills?
1 Solution
HP 710 Scan Problem
I am getting this double line down the paper when I scan. No problem with printer, just scanning feature. HELP ! ...
2 Solutions
nc400
probleme de rayure sur imprimante
Post a Solution
driver
can't find a nc-1000 driver at fuji, only nc-400 both using scsi port. i had this working last year but moved to new...
Post a Solution
Error H010 S10 displayed on the LCD panel
An error code:H010 S 10 is displayed on theLCD panel and I can't pull the paper supply tray nor the trash box out.
Post a Solution
toner refilling - Written by jsaha
Refilling - Written by DARKLORD1
ggg - Written by el3ssaal_171
DRIVER DOWNLOAD - Written by choudharysal
CLOGGED CARTRIDGE - Written by DARKLORD1
clear a paper jam - Written by farnkl3
Steps to install alternate drivers for HP... - Written by nanicool
How to clear paper jam in inkjet printers - Written by Ajkill
How to Cut Printing Costs on Inkjet Color... by wikihow
Drivers, Software, lost C.D....come this... by Soulvisitor
Inkjets and Laser Priners, Inks,... by Soulvisitor
Lexmark All-in-One x3350 by TTonyTigger
How to Check if Your Printer Has Run out... by wikihow
Specifications
Key Features
Technology (Detailed)Thermal Transfer
Black Print Speed80 sec/print
Max Resolution (BW)300 x 300 dpi
Technical Features
Connectivity TechnologyCable
Dimensions
Depth15.2 in.
Fuji Contact Information
Main support number800-755-3854
Sponsored Links
Top Experts
Powered by
Repair Service
Find Printer Repairman Near You:
