20 Most Recent Crate CA30DG Taos Acoustic Guitar Amp, 30 Watts RMS, Dual Inputs, 3 Band EQ with Mid Contour Questions & Answers
Effects don't work
On some amps there needs to be a footswitch inserted in the control jack to activate the effects circuit. Contact Crate to see if that's the case with your amp. http://www.crateamps.com/support/index.php
11/25/2022 5:59:19 AM • Crate CA30DG... • Answered on Nov 25, 2022
2answers
I just picked up a Crate VTX 212 amp. It sounds great! However, it hums a little louder than it should. I'm thinking it's a bad ground somewhere? Anyone out there deal with this before?
Check your guitar with another amp, or a different guitar with this one with no effects pedals, etc, to narrow it down to just the amp. At that point, try reversing the polarity. If none of the above helps, you may indeed have a bad ground somewhere and you'll need a tech to follow it to the source.
12/7/2023 3:04:02 AM • Crate Music • Answered on Dec 07, 2023
2answers
Buzz across all channels in crate rfx120
I also have this issue. Same crate combo amp. There is a loud buzz emitted only when there is a cable plugged in. Cables and instruments checked good, only possible issue is inside the input of the amp. Popped it open, solders and connections were intact and appeared solid. Anyone have a guess as to why this is happening?
11/25/2022 6:21:12 AM • Crate Music • Answered on Nov 25, 2022
I have a Crate PA-4+. I'm looking for the wiring schematic. So fay I've found everything but the 4+.
It is a very simple amplifier and the pa4a is similar.
4/22/2021 7:10:36 AM • Crate Music • Answered on Apr 22, 2021
Schematic crate g60xl
https://www.google.com/search?q=Schematic+crate+g60xl&oq=Schematic+crate+g60xl&aqs=chrome..69i57&sourceid=chrome&ie=UTF-8
12/1/2020 11:32:44 AM • Crate Music • Answered on Dec 01, 2020
2answers
Schematics far crate amp gx-30m
Request from Crate
11/1/2020 10:38:32 AM • Crate Music • Answered on Nov 01, 2020
My crate bx-160 blowing fuses
bad output transistors.
8/21/2019 7:03:40 PM • Crate Music • Answered on Aug 21, 2019
2answers
Sounds fades out when playing
Clean the volume and tone pots with de-oxit cleaner
5/2/2019 8:36:19 PM • Crate Music • Answered on May 02, 2019
Crate fw120h won't switch to clean or high gain channels from the head
Try with a on/off footswitch Wrong cable, or bad PCB connection switch on main tone board.
5/2/2019 7:15:13 PM • Crate Music • Answered on May 02, 2019
I need the website or phone number for Crate
SLM sold the company years ago to Loud audio. Its only supported online now. Loudaudio.com
5/2/2019 7:13:49 PM • Crate Music • Answered on May 02, 2019
Crate GX 40- C schematic
Power supply capacitors failed. This is a common problem with 1990's crates, also the power on "POP".
5/2/2019 7:09:02 PM • Crate Music • Answered on May 02, 2019
Crate GX-130C FIND WIRING DIAGRAM
https://www.amprepairparts.com/schematics.htm Use the GX-65, its the same preamp shopwn just with 2 power amp sections
5/2/2019 7:04:51 PM • Crate Music • Answered on May 02, 2019
2answers
Crate b80 xl amp cuts out bang on top ok until hit low note then hit top again it works again crazy
There is a short somewhere, check your wiring and solder points.
5/1/2019 7:41:30 PM • Crate Music • Answered on May 01, 2019
2answers
I have a crate vtx 212 amp and the power comes on but none of the chanels comes on and no sound what so ever comes out. Nothing looks burnt or corroded idk what the problem is i need help lol
If sure that power is reaching and getting into unit, then confirm that a signal is also reaching unit. If both are positive, then your gear is FUBAR if signal is going into correct input.
3/3/2019 12:06:00 AM • Crate Music • Answered on Mar 03, 2019
I have a crate fxt120 and I cant play through the input. The amp pops anytime i turn the volume knob. I can play through the insert jack I just have no control over the sound. Is this the input jack failing or one of the knobs
1. Sounds like it's the input jack., but it could be the volume knob. Have you tried turning Gain1 and Gain 2 or the Clean Channel volume? Try them first when you're plugged in to the jack on the left , then when you're plugged in the back. If none of these work, it's most likely the preamp. 2. Even if the preamp is shot, there's a quick fix - get a guitar preamp or an effects pedal - they have volume and tone controls. 3. Finally - many pros just plug into the aux jack(on the rear panel) and control the volume and tone through their instruments. Hope one of these works. Good Luck.
12/26/2018 6:58:04 PM • Crate Music • Answered on Dec 26, 2018
I NEED THE SPECS FOR THE CRATE GT-200 AMP MAIN TRANSFORMER
Contact the Crate Service Department at 1-800-738-7563 or 314-569-0141 (8:30am-5:00pm central time, Monday-Friday) to order any parts and/or schematics.
8/5/2018 5:02:01 PM • Crate Music • Answered on Aug 05, 2018
Need amp schematic for a Crate model vc6112
Web page with schematics and requests:http://music-electronics-forum.com/t26486/http://music-electronics-forum.com/attachments/15279d1315547654-crate-vc6112.pdfhttp://music-electronics-forum.com/t16609/http://music-electronics-forum.com/attachments/7268d1260872380-crate_vc6112_271pwa_5.pdfhttp://music-electronics-forum.com/attachments/7269d1260872394-crate_vc6112_271sch_5.pdfhttp://music-electronics-forum.com/sitemap/f-60.htmlUser guide at link below from 1998 has mailing address in St. Louis. https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=3&ved=0ahUKEwit2JO06LbZAhVG2GMKHflPAxEQFgg4MAI&url=http%3A%2F%2Fpdfstream.manualsonline.com%2F6%2F6d0e7f56-c06e-40bc-9925-bb1c66338de7.pdf&usg=AOvVaw1Qy5Pze8vKekErxgjmMg0U Crate VC 6112 Owner Manual
2/21/2018 10:53:20 AM • Crate Music • Answered on Feb 21, 2018
Crate CA30DG Taos Acoustic Guitar Amp, 30 Watts RMS, Dual Inputs, 3 Band EQ with Mid Contour Logo
2 questions posted
Top Crate Music Experts
Ngoro
ADMIN Andrew
ADMIN Andrew
Are you a Crate Music Expert? Answer questions, earn points and help others
View Most Popular
Crate Music
  • Crate Music
Most Popular Question
effects dont work
  • Music
