20 Most Recent Behringer MX9000 EURODESK 24 Channel In line microphone /Line Mixing Console with Integrated Meter Bridge Questions & Answers
2answers
What is wrong with it?
FIlter capacitors in the positive supply are likely failing. These will be the larger metal cans- one may be bulging. Either way, one of them is shorting out after a certain voltage potential is achieved and causing your problem.Replace the caps in both the positive and negative power supply sections and this should alleviate the issue. Match the working voltage rating, or even one step up in working voltage. yours are likely rated 25 volts, so a step to 35 volts would not pose an issue.
1/27/2019 7:43:23 PM • Behringer MX9000... • Answered on Jan 27, 2019
Input gain pots not working the others ok
unfortunatly this would not be a user servicable problem and would need to go to the shop. Here is a link to Behringer contact page. Scroll down to the Locate a service center link. BEHRINGER Limited Warranty
2/26/2015 3:17:54 PM • Behringer MX9000... • Answered on Feb 26, 2015
I need a schematics power supply for MX9000EURODESK
Check out elektrotanya.com you can get 2 circuits per day or pass the electronics test for more. Good Luck!
1/2/2015 6:37:38 PM • Behringer MX9000... • Answered on Jan 02, 2015
I have a Behringer PMP2000D Europower 800-Watt 14-Channel Powered Mixer & I'm getting no sound out of channels 1-6 but I'm getting a signal just no sound & fuses are fine
You will need an oscilloscope and a good grounding in electronic servicing to attempt a repair. But, check the signal routing. Refer to the user manual.
1/18/2024 7:34:56 AM • Behringer Music • Answered on Jan 18, 2024
I have a Behringer Xenyx 1204FX and the DSP Display doesn't illuminate (but works by pressing down and turning the knob). Any idea why it's not on? Also the AUX 1 Send doesn't seem to be working
It sounds like you're experiencing a couple of issues with your Behringer Xenyx 1204FX mixer. Let's address each of these problems separately:
  1. DSP Display Not Illuminating: The fact that the DSP display works when you press down and turn the knob suggests that the issue might be related to the display itself or its connection. Here are a few steps you can take to troubleshoot the problem:
    • Check Power Source: Ensure that the mixer is receiving proper power and is turned on. Sometimes display issues can be caused by power-related problems.
    • Connection: Make sure the ribbon cable or connector that connects the display to the circuit board is properly seated. A loose connection could be causing the display to not illuminate.
    • Faulty Display: If none of the above steps work, there might be a problem with the display itself. You may need to contact Behringer support or a professional technician to get the display repaired or replaced.
  2. AUX 1 Send Not Working: If the AUX 1 send is not working as expected, there could be several reasons for this:
    • Routing Settings: Make sure that the AUX 1 send is properly routed to the desired destination. Check the routing options on the mixer to ensure that the signal is being sent to the correct output or destination.
    • Level Controls: Verify that the level controls for AUX 1 are set correctly. Make sure that the AUX 1 knob for the specific channel you're working with is turned up.
    • Effects/Processing: If you're trying to send a signal with effects applied, check if the effects are set up correctly. Sometimes, an incorrect effect or routing setting can affect the AUX send.
    • Cable and Connections: Ensure that the cables connecting the AUX 1 send to external devices (such as monitors or effects units) are functioning properly and securely connected.
    • AUX Master Level: Confirm that the AUX 1 master level (usually located on the main output section of the mixer) is turned up to an appropriate level.
If you've gone through these troubleshooting steps and the issues still persist, it might be a good idea to consult the user manual for your Behringer Xenyx 1204FX mixer for further guidance. If the problems continue, you may need to reach out to Behringer support or consider seeking assistance from a professional audio technician or repair service.
8/6/2023 8:22:16 AM • Behringer Music • Answered on Aug 06, 2023
2answers
Behringer Europower PMP 1680S--The FX channels both Master and Monitor banks do not create any effects but instead only produce a rapid, repetitive clicking/popping noise. HELP!
Hello Geoff, try using an external processor and check that it works well, if so, the problem is that you have the Jack connectors of Effect sending and those of Return of Effects, dirty Apply a couple of drops of oil, type WD40, to a Plug connector and insert and remove them repeatedly in each connector Jack for sending and returning effects I hope you can solve the problem, comment the results Greetings Franco Dosil Hola Geoff, prueba usando un procesador externo y comprueba que funcione bien, si es asi, el problema es que tienes los conectores Jack de envio de Efecto y los de Retorno de Efectos, sucios Aplicale en un conector Plug un par de gotas de aceite, tipo WD40 y entralos y sacalos repetidamente en cada conector Jack de envio y retorno de efectos Espero puedas solucionar el problema, comenta los resultados Saludos Franco Dosil https://media.music-group.com/media/PLM/data/docs/P0A8M/PMP1680S_PMP980S_PMP960M_M_EN.pdf https://c3.zzounds.com/media/PMP1680S_P0A8M_OI_EN_ES_FR-df44b2314272dfc61a7cabe5bb88ecce.pdf
7/29/2023 2:29:41 AM • Behringer Music • Answered on Jul 29, 2023
2answers
Behringer truth 2031a popping and sizziling stoppeed working, what to check first.
Check all the wiring connections on the speaker. Check the plug in points for the cables are not loose in the body of the speaker or the connector plugs themselves are not loose in the actual plug sockets. Next you will need to get inside the speaker body to check the connections and soldered joints. Take a good look at the back of the cable plug sockets and to the back of the actual speaker cone connections. Check each wire at Both ends for damage. No sound at all suggests the issue might be at the 'Input' where the cable plugs into the back of the speaker body.
7/18/2023 3:07:48 PM • Behringer Music • Answered on Jul 18, 2023
Behringer Europower pmp1680s Head/mixer rapidly powers up and down continuously
Sounds like a capacitor is bad.
6/26/2023 1:13:56 AM • Behringer Music • Answered on Jun 26, 2023
Behringer Ultracoustic acx1800 cd right input not working. Any ideas of what blew?
If the right input on your Behringer Ultracoustic ACX1800 CD is not working, it could be due to a number of reasons, including:
  1. A faulty cable or connection: The problem could be as simple as a loose or damaged cable. Try swapping out the cable with a known working cable or check the connection to ensure that it is secure.
  2. A blown fuse: The ACX1800 CD has a built-in fuse that protects the internal components from power surges or other electrical issues. Check the fuse to make sure it is not blown and replace it if necessary.
  3. A damaged preamp or amplifier circuit: If the problem is not with the cable or fuse, it could be due to a damaged preamp or amplifier circuit. This can be caused by a number of factors, such as overheating, power surges, or other electrical issues. In this case, you may need to take the ACX1800 CD to a professional repair technician to diagnose and fix the problem.
  4. A faulty right channel input jack: It is also possible that the right channel input jack itself is faulty. This can be caused by wear and tear over time or physical damage. In this case, you may need to replace the input jack or have it repaired by a professional technician.
4/10/2023 12:51:16 PM • Behringer Music • Answered on Apr 10, 2023
Behringer EuroLive B115D. Turning up the volume on the inputs you lose lows you lose highs. It's just popping and going up and down in volume.
Question edited for clarity and the real name of the model, plus all the typos. Send it back and claim a 3 year warranty repair. It may be dirty controls, but could also be failed internal components like blown capacitors. https://www.behringer.com/service/service-warranty.html?modelCode=P0AEB https://www.google.com/search?q=Behringer+EuroLive+B115D ..
4/10/2023 12:37:58 PM • Behringer Music • Answered on Apr 10, 2023
Behringer MS16 transformer voltage ?
MS16? Please clarify. What is it.
4/10/2023 12:37:06 PM • Behringer Music • Answered on Apr 10, 2023
PMH 5000 and External Amps...
Based on my research, the Yamaha PMH5000 mixer features two 1/4-inch "insert" jacks for connecting external effects processors, such as compressors or equalizers, to individual channels. These jacks are not intended for connecting external power amps. However, the PMH5000 does have two "main out" jacks that can be used to send the mixed audio signal to external power amps. These are typically located on the back of the mixer and may be labeled as "L/R" or "Main Out." When you connect an external power amp to the main out jacks, the signal is sent directly to the power amp and is not routed through the internal power amps of the mixer. The external power amp then amplifies the signal and sends it to the speakers. It is important to note that when using external power amps, you should adjust the volume levels carefully to avoid damaging the speakers or the power amp.
4/10/2023 12:32:56 PM • Behringer Music • Answered on Apr 10, 2023
Hi i have a behringer b815neo with damaged surface mount components,what values are d51,r26,and c33 ?
I'm sorry, but without additional information such as a schematic or a more detailed description of the location of the components, it is difficult to determine the exact values of D51, R26, and C33 in your Behringer B815neo speaker. It is recommended that you contact Behringer customer support or a professional audio repair technician for assistance with repairing your speaker. They may be able to provide you with the necessary information and guidance to identify and replace the damaged components.
4/10/2023 12:32:13 PM • Behringer Music • Answered on Apr 10, 2023
My X Vamp is making
Bummer dude. Sounds like a capacitor or processor problem. Behringer stuff is really not very repairable. I have had to scrap lots of the stuff over the years. Great while it works and very affordable
12/31/2022 12:36:20 PM • Behringer Music • Answered on Dec 31, 2022
Behringer MX9000 EURODESK 24 Channel In line microphone /Line Mixing Console with Integrated Meter Bridge Logo
5 questions posted
Top Behringer Music Experts
john h
Are you a Behringer Music Expert? Answer questions, earn points and help others
View Most Popular
Behringer Music
  • Behringer Music
Most Popular Question
no output from inputs meter light ups
  • Music
