20 Most Recent Fender Musical Instruments Corporation Fender 013 5300 332 Deluxe Nashville Telecaster Electric Guitar Questions & Answers
This guitar is from the U.S. Vintage Series
made at the Corona Plant (Fender), USA
in the Year(s): Cannot be determined from serial number,
however you can consult this chart showing the
corelation between serial numbers and dates found on the neck
Fender MIA RI Serial Number vs. Neck Date (Note the earliest I'm seeing is mid 80s)
Fender Music | Answered on Jun 12, 2019
first checkout your cable
if you still have problem , change you pickup
Fender Music | Answered on May 22, 2019
The Fender Hot Rod Deluxe has been around since 1996
Fender Music | Answered on Apr 06, 2019
While it is possible (probable) it is caused by the AC mains modulating the output due to a power supply fault, it could be caused by inadvertently creating a hum loop due to poor grounding - check out the link below...
https://www.google.com/search?q=hum+loop+audio&rlz=1C1CAFB_enGB673GB676&oq=hum+loop&aqs=chrome.4.69i57j0l5.8500j0j8&sourceid=chrome&ie=UTF-8
Fender Music | Answered on Mar 24, 2019
Does it still have a hum/buzz when NOTHING is plugged into the INPUT? If so, you MAY have a tub going bad. If the noise is only there when you have your guitar/effects, etc. plugged in, then the problem is the guitar grounding or effects faulty...
FIRST: When the amp is "cool", UNPLUG THE AMP POWER CORD FROM THE WALL! ! ! ! Then CAREFULLY remove and reseat the tubes one at a time. Be sure to insert back into the socket correctly. You MAY just have a bit of corrosion on the tube "pins"....
SECOND:Don't plug anything into the amp, turn on and warm up. GENTLY tap one tube at a time with a WOODEN pencil. DO NOT USE anything metallic (like a screwdriver....) and be VERY gentle. If the noise increases or decreases, you probably have a tube going bad...
That's all I have. If this doesn't cure the issue, best take it to a repair shop . . . .
Fender Music | Answered on Mar 02, 2019
You have to get the volume pot cleaned and lubricated. If not a quick replacement should do.
Fender Music | Answered on Feb 11, 2019
You could buy a Lehle switch, or simply use one on each separately. If you are using a multieffect unit you could make a Y cable to take the output to both amps but that will not allow you to select the drive channel - you still need the Fender footswitch for that, one for each amp. Lehle is a German company and they make a lot of different footswitch combinations but you will pay for the convenience.
I recommend the Fender single button footswitch for this use - Type: Footswitch
  • Number of Footswitch Buttons: 1
  • Manufacturer Part Number: 0994052000
  • It's about $35.00 each, compared to the Lehle which starts at $200. Just put the two side by side and make a metal bar to attach to the two switches - then you have a single bar to activate both drive channels at the same time. I recommend using aluminum bar stock with holes drilled into it for the switches, or find a C channel aluminum bar that will put the footswitch buttons in the channel. You can also make it one inch overhang past both switch bodies and then use bolts to keep the bar in place. If I was doing this I would mount the footswitches on a board and secure the bar to be on top of the footswitches, using coil springs to maintain the bar's alignment vertically at the end bolts.
  • Fender Music | Answered on Jan 18, 2019
    Google (fender)(AX-12)(manual) without parens.
    Fender Music | Answered on Jan 12, 2019
    It should be possible. In any case, the reverb spring assembly can be removed carefully and unplugged (should have RCA plugs). When mounting the casters, make sure the fasteners don't conflict/block the reverb mountings.
    Fender Music | Answered on Nov 10, 2018
    Either on the head stock or on the neck, between the neck and body. Once you have the serial number, you will be able to find out where and roughly when it was made. The price is liable to be anything.
    Fender Music | Answered on Aug 04, 2018
    Fender Musical Instruments Corporation Fender 013 5300 332 Deluxe Nashville Telecaster Electric Guitar Logo
    1 questions posted
    Top Fender Music Experts
    Michial Gueffroy
    rjivaro
    Marvin
    Marvin
    Are you a Fender Music Expert? Answer questions, earn points and help others
    View Most Popular
    Fender Music
    • Fender Music
    Most Popular Question
    serial number 12121297
    • Music
