20 Most Recent LG GSA-4082BI DVD±RW Burner Questions & Answers
Start the Run Command Prompt
Type in "regedit" without the parrenthesis then click ok
Go to HKEY_LOCAL_MACHINE
Then SYSTEM
Then CURRENT CONTROL SET
Then CONTROL
Then CLASS
Then find {4D36E965-E325-11CE-BFC1-08002BE10318}
The whole thing looks like this:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
Then delete the upper and lower filters.... (if lower filter is not there then leave it)
RESTART YOUR COMPUTER THEN THERE YA GO!!!! HOPE THIS HELPS
LG GSA-4082BI... | Answered on Feb 06, 2009
Get a new drive, look around the net... these things are garbage. Mine has the opposite problem of yours. Recognizes everything but DVDs.
LG GSA-4082BI... | Answered on Aug 28, 2008
Check that the writable DVDs you are using are compatible (+/-) with your LG DVD-RAM.
Go to Windows Explorer and check to see if the Sony drive is visible. It may not be connected or the Jumper switch may be set incorrectly.
Check you have drivers installed, take a look in Hardware manager.
Sometimes, it's a little difficult to copy CDs and DVDs when you have more than one burning suite installed - for some reason, they 'just don't get along'. Try uninstalling any suites other than Nero.
Or it may just be that your LG CD-RW drive is just that, and your DVD-RW drive is just that. So it wouldn't be possible to write DVDs on the CD-RW and CDs on the DVD-RW? Though I would assume Nero would detect that and use your hard-drive as temporary storage.
In Nero SmartStart, have you selected the CD or DVD tab to correspond to the project you're burning?
LG GSA-4082BI... | Answered on Feb 04, 2008
This requires more technical in person diagnosis. some things you can try are to boot in to the bios menu.
  • To do this you will have to watch as it is turning on and on one of the startup screens it will tell you to press one of the function keys (F10, F2,F12, and so on) click the one that says "bios" or "settings".
  • After that you will need to search through all the settings for something called the "IDE self test" run that once, it will take a while.
  • and lastly look for another option called the boot order. you have to make sure that the option that says hard drive is first.
I am sorry i can't be of more assistance but not much can be done without seeing the laptop.
LG Computers &... | Answered on Aug 25, 2019
On the phone you would need to gointo settings > wireless and enable your wireless radio. You should then get a notification that wireless networks are available. Select your's or a public wireless network if you're at a coffee shop, ect. Enter any applicable passwords. For this to work you need to verify your phone has wireless capabilities and that the phone and router support the same 802.11 standard. Current Standards are a,b,g,n and ac
LG Computers &... | Answered on Aug 22, 2019
The address bar may have been hidden in the settings options, usually it is near other settings such as "show Menu bar" and "show bookmarks Tab" etc
LG Computers &... | Answered on Aug 15, 2019
Try a reset. The Reset button is on the front panel in the bottom right corner. Once you open the cover you will need a long pin to push the reset button hole. Be patient as it takes a while to boot up.
LG Computers &... | Answered on Jul 12, 2019
LG GSA-4082BI DVD±RW Burner Logo
3 questions posted
Top LG Computers & Internet Experts
Ekse
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
GSA LG
  • GSA LG
Most Popular Question
lg gsa 4082 n
  • Computers & Internet
