20 Most Recent LG (GCC4243N) CD-RW/DVD-ROM (Combo) Burner Questions & Answers
Try uninstalling the Driver in Device Manager: in XP or earlier: Start/Control Panel/System/Hardware Tab/Device Manager, or in Vista & 7: Start/Control Panel/Device Manager.
Once in Device Manager click on the + sign that is in front of 'DVD/CD ROM drives' to open it up, then right click on the model of the Optical Drive in question.
Click Properties/Driver Tab/Uninstall (Advanced) & this will remove the driver if it is corrupt. Restart your system & the Hardware Manager will recognise the Optical Drive & install the necessary Driver.
If this doesn't solve your dillema then I hope that you have a warranty. Good luck in trying.
Kindest regards,
Ste
LG (GCC4243N)... | Answered on Mar 14, 2013
click start control panel administrive tools computer management device manager scroll down cd dvd rom drives if you see a yellow question mark? right click you will have options to update driver,roll back driver,or
select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall
Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
Hope this helps
LG (GCC4243N)... | Answered on May 01, 2011
Take a paper clip now straighten it push it in the tiny hole on the front of the CD ROM drive
the drive should open
LG (GCC4243N)... | Answered on Apr 12, 2011
what brand , model number, and operating system you are using,,,
LG (GCC4243N)... | Answered on Nov 30, 2008
if you have lance cleaner then use it but shyore it one famouse brand otherwise it should damage yor cd om's lance if you found nothing then pls go to your hardware vendor
LG (GCC4243N)... | Answered on Apr 29, 2008
This requires more technical in person diagnosis. some things you can try are to boot in to the bios menu.
  • To do this you will have to watch as it is turning on and on one of the startup screens it will tell you to press one of the function keys (F10, F2,F12, and so on) click the one that says "bios" or "settings".
  • After that you will need to search through all the settings for something called the "IDE self test" run that once, it will take a while.
  • and lastly look for another option called the boot order. you have to make sure that the option that says hard drive is first.
I am sorry i can't be of more assistance but not much can be done without seeing the laptop.
LG Computers &... | Answered on Aug 25, 2019
On the phone you would need to gointo settings > wireless and enable your wireless radio. You should then get a notification that wireless networks are available. Select your's or a public wireless network if you're at a coffee shop, ect. Enter any applicable passwords. For this to work you need to verify your phone has wireless capabilities and that the phone and router support the same 802.11 standard. Current Standards are a,b,g,n and ac
LG Computers &... | Answered on Aug 22, 2019
The address bar may have been hidden in the settings options, usually it is near other settings such as "show Menu bar" and "show bookmarks Tab" etc
LG Computers &... | Answered on Aug 15, 2019
Try a reset. The Reset button is on the front panel in the bottom right corner. Once you open the cover you will need a long pin to push the reset button hole. Be patient as it takes a while to boot up.
LG Computers &... | Answered on Jul 12, 2019
if you are speaking of the dual inverter, I cannot help you. This is not a computer question
LG Computers &... | Answered on Jun 09, 2019
LG Smart TV with Google TV - Chrome - YouTube
? 0:53
https://www.youtube.com/watch?v=8raYGWZWb4s
Feb 6, 2013 - Uploaded by LG USA Home Appliances and Electronics
LG's. Google Chrome browser is waiting right here on. the right end of your launcher bar click. the ...
is it possible to download google chrome on a L G SMART TV ...
https://productforums.google.com/forum/#!category-topic/chromebook-central/... Mar 5, 2015 - If you are reporting an issue or looking for troubleshooting help, please provide the following information and a detailed description of your issue: Chrome OS Version (Type chrome://help in your browser window's address bar. Copy and paste the first three lines you see here.): Chromebook Model ...
LG Computers &... | Answered on Jun 06, 2019
Your TV's backlight most likely has reached its end of life cycle (pundido na). Try illuminating the screen with a flashlight (flashlight test) and if you see the picture partially, the led lamp needs replacing.
LG Computers &... | Answered on Jun 05, 2019
Test your laptop and fix it using Norton Utilities (download and run it):
http://download.cnet.com/Norton-Utilities/3000-18512_4-10907620.html
LG Computers &... | Answered on Jun 04, 2019
LG (GCC4243N) CD-RW/DVD-ROM (Combo) Burner Logo
9 questions posted
Top LG Computers & Internet Experts
Ekse
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • LG Computers & Internet
Most Popular Question
cd rw dvd combo drive gcc 4242n writing
  • Computers & Internet
