20 Most Recent
Mach Speed VENOM V2DP Motherboard Questions & Answers
Onboard video not working
If you have configured it to be the secondary video adapter in the bios, then it will not work as it has to be set as the primary graphics.
the bios will still be looking for your AGP graphics card as the primary and bypass your on board graphics.
If you need to use on board graphics, right click the graphics card in properties>hardware>device manager and select dissable or uninstall.
Motherboard (MSNV-939) won't power-up
Well, based on what you are saying, I would say that the motherboard has been affected in some way. Try reseating the CPU and the RAM, then try powering it up.
What is venom?
hi im josh in cebu phils . Venom literally means a poisonous substance in animals and plants but in PC it is only a code brand which means tough strong or powerful The V2DP is our newest addition to the Venom motherboard line. Mach
Speed has taken one of our best selling motherboard, the V4MDMP, and
made a low cost solution with a 333 Front Side BUS and 4x AGP slot
producing an awesome all-in-one, low cost motherboard. The Venom V2DP
is a very versatile motherboard on todays market. This feature enriched
motherboard supports AMDs Athlon XP 333FSB processors, DDR 333 memory,
and has a 4x AGP slot for High Performance systems or take advantage of
the Integrated Video, Sound, and 10/100 LAN for a cost effective
solution. The integrated UniCrome 64mg Video is ready for crystal clear
DVD playback and high-resolution gaming. On Board 3D 6 Channel Sound
will take full advantage of your high fidelity sound system and onboard
10/100 LAN is ready for broadband internet or a high speed network thats all hope i helped you.
Mach Speed V2DP Motherboard
If you can, could you check your cmos battery, to see if it's flat.
then come back.
Some boards need the battery to even boot not to just hold bios sttings.
You also have to bear in mind if the proccessor isn't working it will go no further than power up.
Also, removing cmos battery doesn't clear cmos on all mobo's, you have to put jumper across pins 2-3 on JBAT1 terminals and then back to pins 1-2.
Why did you need to clear the cmos; have you done any upgrades?
SATA Hard Drives
coonnect your sata connection to hdd and aslo its other side to motherbord it is nesar the ide connector.
Video controller
use unidentified device drivers (download) it searches for all drivers needed on motherboard locate video driver info note name and number do a search for them download install.
the above program has helped me alot to find unknown drivers
HELP ME PLease!!!
theres 2 types of engines. the non turbo is usually similar to a neon chrysler.. ( i have one) computer is under hood by the "bubble" not a real mitsubishi comptuer which is inside the car nto unde the hood.
ecu by fusebox=chirsler RS model if ecu inside car mitsubishi.
try dsm.org
My tablet is stuck on the start up screen.
The BIOS information is typically found at or near the top of the POST screen for a very short time
ALR PC non / PCI =CTRL+ALT+ESC
AMD advanced micro devices=BIOS = DEL
Award BIOS = DEL
Dtk Datatech Enterprises Co. BIOS = ESC
Phoenix BIOS = CTRL+ALT+S
Phoenix BIOS = CTRL+ALT+INS
Restart your computer
during the boot process you will see on the screen to press a certain key usually Delete or F2 to enter setup
this will differ depending on which bios you have
Press and hold that key during the boot up process to enter BIOS
if you have changed any of the BIOS settings by mistake
you can load failsafe or optimised defaultsusing the arrow keys you can after you make any changes in BIOS press Esc then press the F10 button save to cmos to restart
CMOS is an on-board semiconductor chip powered by a CMOS battery inside computers that stores information such as the system time and date and the system hardware settings for your computer..
this will reset your cmos
