20 Most Recent Indesit IDP 127 NX Dishwasher Questions & Answers
Ids 105 dishwasher indesit running for 5 to 6 minutes then going to end cycle
control board issue, technician will have to test and repair or replace press the helpful button
2/5/2016 4:39:03 PM • Indesit IDP 127... • Answered on Feb 05, 2016
Indesit DFG 15B1 Ecotime Freestanding Dishwasher (U.K.) won't start. Powers on.
Question edited for clarity. It could be many things, failed pump motor, failed mainboard and as you say, the door switch. There are some ideas in the link, but you would be advised to call your local Indesit Service Agent. Try a power cycle reset. https://www.google.com/search?q=indesit+dishwasher+won%27t+start+but+has+power ..
6/16/2023 2:25:22 PM • Indesit... • Answered on Jun 16, 2023
Indesit Washing Machine Reset Not Working
If your Indesit 6165 washing machine is not responding to the reset button and is only turning off when you unplug it, there could be a problem with the control panel or a fault with one of the internal components. Here are a few steps you can try to troubleshoot the issue:
  1. Unplug the washing machine and leave it unplugged for a few minutes. This will allow any internal components to cool down and reset.
  2. Check the filter to make sure it is not clogged. A clogged filter can cause the washing machine to malfunction.
  3. Check the inlet hose and make sure it is not kinked or bent. A bent or kinked hose can restrict the flow of water and cause problems with the washing machine.
  4. Check the control panel for any loose or damaged wires. If you find any loose or damaged wires, try to secure them or repair them as needed.
  5. Check for any error codes displayed on the control panel. Error codes can help identify the problem with the washing machine and suggest a solution.
1/2/2023 5:00:49 PM • Indesit... • Answered on Jan 02, 2023
Dishwasher door tension adjustment
3/29/2022 5:11:11 PM • Indesit... • Answered on Mar 29, 2022
Virtual sensor Indesit DIF 04B1 integrated dishwasher reset ?
You've verified that water is available at the inlet. The owner's manual suggests checking and cleaning the filters (Troubleshooting, page 33). The instructions for doing this are on page 32, linked below. Perhaps the dishwasher loaded up the filters when it didn't have incoming water to flush out the debris at the end of the wash cycle. If after cleaning everything it still doesn't work, we're back to a burned-out inlet solenoid valve. If you're familiar with electrical equipment, you can disconnect power to the dishwasher, disconnect one or both terminals from the solenoid coil (so other connections in the dishwasher don't interfere with the measurement) and measure the resistance of the coil. If it reads infinite on any range, or more than a million ohms, the electromagnet coil is burned out and the coil or valve assembly will have to be replaced.
2/15/2022 5:54:42 AM • Indesit... • Answered on Feb 15, 2022
Indesit DIF 0481 flashing ALL lights
Turn off the water to the dishwasher and unplug it. Disconnect the water line to the dishwasher and place it in a bucket. Have somebody turn the water back on until water goes into the bucket (it may spit, then spray hard), then immediately turn the water off. (If there is a shutoff right at the dishwasher, this is a one-person job. If not, you'll have to holler to the person standing by at the main valve.) Reconnect the water line. This should take care of any vacuum/air lock issues at the inlet; if the dishwasher doesn't see water flow right away, it may be tripping the error signal. The worst case I can imagine is that the inlet water solenoid valve overheated because it was on for a long time with no water flowing through it. It may be stuck or burned out.
2/13/2022 7:59:56 PM • Indesit... • Answered on Feb 13, 2022
3answers
Indesit BI WDIL 7125 UK keeps stopping during tumble drying and lock light flashes
Check/adjust the door catch.
10/21/2021 6:44:22 AM • Indesit... • Answered on Oct 21, 2021
Indesit dishwasher restarts new cycle after completing cycle. Is there a reset method?
Moved Category from Cars and Trucks! Unplug it or turn off the breaker for at least 24 hours. https://www.google.com/search?q=indesit+dishwasher+dif04+reset ..
10/6/2021 5:01:47 PM • Indesit... • Answered on Oct 06, 2021
Had got a Indesit 340 dishwasher, it's not working satisfactorily. Kindly help.
What is it not doing satisfactorily?
7/15/2021 7:04:20 AM • Indesit... • Answered on Jul 15, 2021
DFG 262. Why are 1 and 3 LEDs blinking and the program stops?
ask DFG who ever that is
4/20/2021 3:22:55 PM • Indesit... • Answered on Apr 20, 2021
2answers
Why is there a red light and it doesn't start?
There is no power, the device isn't connected or there's no signal. You may be using the wrong wire or try re-connecting it.
12/28/2020 11:27:07 AM • Indesit... • Answered on Dec 28, 2020
My Indesit IDS 105 slimline dishwasher won't finish its cycle, it stops a few minutes in.
Try cutting the power to the dishwasher (remove the fuse) for about 30 seconds, then when you put the fuse back in, do it quickly and smoothly so you get a clean power-on without a lot of sparking. This may get the dishwasher controller to do a proper hard power-on reset. If the problem persists, you may have a hardware failure in the controller. The first thing I'd look for is a failing electrolytic capacitor. Sometimes a power on-off cycle finishes them off. Fortunately, the parts are cheap and readily available from online suppliers such as Digi-Key or Mouser. Unfortunately, you have to have electronic component soldering skills to change them. Often, bad capacitors can be visually identified because the top of the capacitor is domed instead of flat, or for smaller units the aluminum casing is partly pushed off of the rubber or plastic base. bad cap2-u1fciducfz4xg24vis3ttoot-3-0.jpeg Contrast the bad capacitor on the right with the good one next to it on the left.
6/5/2019 3:13:42 AM • Indesit... • Answered on Jun 05, 2019
Ihave a black indesit dishwasher the redlight keeps flashing.i have put salt in
red light flashing indicates a problem. If that is all the symptoms then you need a house call. Don't know what the salt is about. If t
5/27/2019 12:58:50 AM • Indesit... • Answered on May 27, 2019
Indesit IDP 127 NX Dishwasher Logo
Popular Tags
1 questions posted
Top Indesit Dishwashers Experts
Paul Bade
NOEL
NOEL
Ngoro
Are you an Indesit Dishwasher Expert? Answer questions, earn points and help others
View Most Popular
Indesit Dishwashers
  • Indesit Dishwashers
Most Popular Question
ids 105 dishwasher indesit running 5 6
  • Dishwashers
