20 Most Recent
Medion MD-40954 Notebook Questions & Answers
How to use my built-in web camera for my medion laptop
hold down the Fn button and press the button with a camera symbol (its F9 on mine) at the same time.
The camera symbol at the bottom right of the screen should show a white circle rather than a red cross. this means it is switched on.
it bugged me for weeks!!
Medion mim2080 notebook
my sugestion is to leave laptop unpluged from wall and removed battery and leave to cool for 3 days and then check on the fourth day replace battery. and reboot laptop. if problem accures take to be repaired, as the hard disc may have over heated plus comntatcs for hard disc and motherboard this is the only help I can give I leave mine on for 5 -6 days somtimes then turn the thing off to cool down the other addvice is if it works get it a laptop cooler which it sits on and keeps it cool.
best of luck on the laptop
Video card problem
Did you try installing a latest driver of your video card? if not try browsing the net and downloading the latest version of your video card driver.
Hotkey for printer settings
Hotkeys provide keyboard shortcuts for common tasks. Some applications lose focus or disappear when you click away or move your cursor on the screen. To capture the active window, use Snagit's hotkeys.Hotkeys also allow you to:
- Quickly switch between commonly-used profiles.
- Maintain the cursor's position on the screen.
- Take captures without interacting with the Snagit interface.
Keyboard types wrong character
The problem is with your keyboard not with its s/w. if u have installed vista and still the problem remains then it is problem of keyboard. pls rush to nearest service center. don't do much experiment
I forget my password bios
To remove the BIOS password all you need to do is reset the BIOS.
To reset the bios all
you need to do is open the side panel of the CPU unit and you shall find a
electronic battery on the motherboard. This is the CMOS battery. Press on the
clip to remove the battery from its slot and wait for a minute. switch on the
PC without the battery and switch off after 30 secs. now reconnect the battery
and your BIOS reset is done.
I think the issue should get resolved.
If you feel that my answers have helped you getting
solution to your problems then please give a vote for best answer.
Cant turn on wireless on medion md98300
try right clicking my computer then device manager see if you have a yellow question mark if its there you need to download its driver if its all good then try fn + the blue antenna on f 8
What is the max
The tech specs show a maximum of 1 GB of RAM on this laptop.
I need the modem driver
http://www1.medion.de/downloads/download.pl?id=1720&type=treiber&filename=wlan714fid2100winmexp.exe&lang=us
Here you are. :)
