20 Most Recent
Pacific Digital X-treme CD-RW Burner Questions & Answers
I lost my power supply cord when I moved. Where
Hello,you can buy one AC to DC voltage converter (usually 1000mA) - which comes with multiple output tips and you manual setting the Volt that are required by your burner(check behind of your burner near the socket that you plug the power it should right ..Volt and the mA or AMP) and adjust the converter
I need the power cord for my 16x usb dvd-rw,where do I get one[s.n.A9G0X2]
you will need usb leadsyou could get this on Ebay if you dont have an account you will need to create one
Add Email adress
Add Bank Acc
Add Credit Card
also add your postal adress
also add a paypal account
when you get to the paypal login page at the bottom you will see new to paypal sign up tab
paypal to create an account
paypal registration password ,bank card /credit card,phone numbers home/mobile ,email adress and a postal adress
http://www.paypal.com/
be very specific when you type in the search
always ask questions? before you make a purchase and keep the email/s for security reasons if the item arrives and its not as described
you will even see the pictures of your item so you cant make a mistake and get them home delivered
hope this helps you
It does not want apareser in my PC when I connect
Does it appear when you try to connect it to some other computer?
If it NEVER appears, then try a different USB cable.
If it still fails to appear, something is broken.
Open the casing, remove the "dead" CD/RW drive, and replace it. Close the casing. Try again.
When burning an audio cd i keep getting (please
make sure that the dvd burner is getting enough power test all leads that are attached to the dvd burner including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
your drivers may have been corrupted or you might have a virus run your antivrus program
you might have to physically unplug the leads for this cd/dvd burner then plug them back in or
you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device
I got this Pacific Digital model 1930-24 in a yard
Possibly not. It depends on what the power points are on the connector. The Pacific Digital 1930-24 uses the following pinout voltages: 1 = +12VDC ; 2 = +5VDC ; 3 = RTN/CMN ; 4 = +5VDC ; 5 = RTN/CMN. The pinout DOES NOT follow a clockwise or counter clockwise position. The pinout starts at the bottom with pin 1 by itself, above it is Pin 2 & 4 above that. On the opposite side is 3 with 5 on top. Or you can view the following image: http://img7.imageshack.us/img7/7204/minidin5p.gif
Again, that is the pinout for the socket on the 1930-24. Some iOmega external CDRWs have the +5VDC and RTN pins swapped. So they would not be a good alternative to use.
How can I get the CD door open on a Pacific Digital CD-RW unit (2.0)?
To get it open: there is a small hole on the front of the unit. Take an unbent paperclip and slowly but firmly push into that hole. The drawer should slide out enough for you to grab it.
Not showing up in windows explorer: google for: upper lower filters dvd drive windows (put your windows version here)
That will tell you what registry entry to remove. Be careful in the registry. Caveat emptor.
I have a Pacific
Welcome to Fixya. I would like to know if this is happening on all other CD's and DVD's? When was the last time you were able to use the device? Please try to use a different cd or dvd to check if the dvdrom is not reading all type of disk. Please provide information needed to be able to provide you the information about the issue.
Thanks
