20 Most Recent
Packard Bell (030069) Sound Card Questions & Answers
I have an Easy Note
hello I might help you First I want you to go to CONTROL PANEL then HARDWARE AND SOUND then SOUND and RECORDING. click on the boom microphone after that PROPERTIES and check the settings AND PLEASE RATE MY COMMENT
Have a Packard Bell tj65
Hello may be their is something stuck in power supply fan or CPU fan open your pc case and see where the noise coming from i hope it helps. Please rate my comment.
I HAVE GOT NO SOUND
This is what you need to do.
* Install the chipset driver first of all.
* Install AUDIO driver
These drivers can be found most of the time on the manufacturers website.
However i've you can't find these driver, you can always use a Driver Update Utility.
DriverEasy is free & good.
Download & How2use
http:\www.drivereasy.com
No audio sound
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers or uninstall
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
click start control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager sound video and game controllers could be a yellow question or exclamation mark ! ? or red x right click to re-install drivers or you might need to download one
cnetdowload.com if these drivers are not suitable on the home page you should see the download software finder under that there will be a list platform, category sub category price from the category drop down list select drivers then from the price drop down list select free or which ever applies to your need
http://download.cnet.com/Realtek-AC-97-Driver-Windows-98-Me-2000-XP-2003/3000-2120_4-10238712.html
http://download.cnet.com/Realtek-High-Definition-Audio-Codec-Windows-Vista-Windows-7-32-bit/3000-2120_4-10788600.html
http://download.cnet.com/%7Bvalue=http://www.download.com/realtek-high-definition-audio/3000-2120_4-75317047.html
Realtek HD audio driver package. The package includes: driver setup program, drivers for Windows Vista / 7 64-bit
http://www.freeware-downloads.com/soundmax_integrated_digital_audio_driver_v.htm SoundMax Integrated Digital Audio Driver v hope one of these helps
I dont have sound card
if you are having problems with your sound
also
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
make sure you have an earth ******** before touching any parts inside your computer
hope this helps
My packard bell is about
settings there
also
icon in taskbar
problem
connection is good
hope this helps
Sound
free download multimedia audio controller 5.1.2535.0
I HAVE A PACKARD BELL EASYNOTE TJ74. WHEN PLUGGING
You don't remove any drivers (or so) by changing the output. Keep the output at the desired one and in case you use the laptop without the TV change the setting in order to use the internal speakers.
In case of a problem or clarification or further details needed, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct fixya link: http://www.fixya.com/users/technical114
I have no sound on
also
hope this helps
don
Sound problem
you might have to uninstall then restart your computer then reinstall both the sound drivers and the sound card make sure you have both of these devices backed up to a disc before uninstalling
a yellow? question mark means you need to install/update driver to do this
right click to install driver also
click start control panel sounds and audio,volume,advanced,speakers select appropriate speakers also audio you will find 3 drop down lists make sure you have the correct settings there
also
hope this helps
No sound in my compiter
you might have to uninstall then reinstall both the sound drivers and the sound card make sure you have both of these devices backed up to a disc before uninstalling
also
hope this helps
My sound is all distorted
Make sure your speakers are correctly connected to your computer.
On your speakers, find the cable that plugs into your computer. Make sure that the speaker cable is plugged into the speakers and the correct jack on the computer. For example, if the cable is a 1/8 inch cable, there should be a round jack for it on the back of the computer. If it is a USB cable, it will plug into any USB port on your computer.
If the music in your library skips or the audio breaks up when you play it inWindows Media Player, there might be a problem with the audio driver installed on your computer. Typically, this type of problem only occurs toward the end of songs (in the last 20 seconds or so).
In some cases, you can work around the problem by disabling optional speaker effects that are collectively known as enhancements. If disabling speaker effects solves the problem, you might need to update your audio driver.
No multimedia audio controller
click start control panel sounds and audio,volume,advanced,speakers select appropriate speakers also audio you will find 3 drop down lists make sure you have made the correct adjustments there
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can make adjustments there you can also tick in the box place icon in taskbar
hope this helps
