20 Most Recent
SPOT SL5W09 Spot Light Questions & Answers
FULL CHARGE LAST 5MIN. MAX
My guess is the batteries are probably no good. All batteries will only last so long and it also depends how often they are keep charged and discharged. Basically all batteries require some kind of maintenance (recharging / discharging).
I have Motomaster Eliminator 2M Series Spotlight/Lantern Combo. The spot light switch quite and I would like to fix it.
Here's what you can do:
- Check Warranty: If your spotlight is still under warranty, you might be able to get a replacement switch or have the entire unit repaired or replaced by the manufacturer. Check the warranty information that came with your spotlight for details on how to proceed.
- Contact Customer Support: Get in touch with the customer support department of the manufacturer or the retailer where you purchased the spotlight. They may be able to provide guidance on obtaining a replacement switch or offer repair services.
- Search for Replacement Parts: Look online for retailers or websites that specialize in selling replacement parts for spotlights and lanterns. You might be able to find the specific switch you need for your model.
- Consider DIY Repair: If you're comfortable with it, you could try opening up the spotlight and examining the switch yourself. Sometimes, switches can be repaired or cleaned to restore functionality. However, this approach requires some technical skill and might void any remaining warranty.
- Seek Professional Help: If you're not confident in your ability to repair the switch yourself, consider taking the spotlight to a professional repair technician. They can diagnose the issue and either repair the existing switch or install a replacement for you.
Remember to prioritize your safety when attempting any DIY repairs, especially when working with electrical devices. If you're unsure or uncomfortable with any aspect of the repair process, it's best to seek professional assistance.
Why wont the spot lights for vec 192 charge ?
Boy, this one is a loaded question.
Could be the charger itself that's defective.
Having a current monitor (Kill A Watt P3), comes in handy to check to see if the wall transformer / charger is drawing any current. That would determine if the charger was working to some degree. The best way is to measure the voltage coming out of the charger itself. It should be low voltage. I would use an digital auto multimeter to check the voltage. The transformer should have written on it somewhere the type of voltage (DC-direct current/AC-alternate current). Be careful not to shorted the end connector as I could damage it.
Could be the cord of the charger that is bad.
Could be the batteries themselves that are bad.
Could be the flashlight internal parts are bad.
Where can I find replacement parts for my rechargeable lantern?
It's great that you're looking to revive your rechargeable lantern! Here are some steps you can take to find replacement parts and ensure your lantern is in working condition:
- Check with the Manufacturer: Start by contacting the manufacturer of your rechargeable lantern. They may offer replacement parts for your specific model, including the light tubes. You can inquire about replacement batteries as well.
- Search Online Retailers: Look for online retailers specializing in selling replacement parts for lanterns and flashlights. Websites like Amazon, eBay, or specialized outdoor equipment stores may carry the replacement light tubes you need. Make sure to check if they ship to Canada.
- Visit Local Hardware or Outdoor Stores: Explore hardware stores, camping supply stores, or outdoor equipment retailers in your area. They may have replacement light tubes or similar products that are compatible with your lantern.
- Consider Universal Light Tubes: If you cannot find the exact replacement light tubes for your lantern, consider purchasing universal light tubes that fit the size and specifications of your lantern's sockets. Be sure to measure the dimensions of the sockets and compare them with the specifications of the replacement tubes.
- Test the Battery: Before purchasing replacement parts, it's a good idea to test the battery to see if it still holds a charge. If you have a compatible charger, you can try charging the battery and observing its performance. If the battery no longer holds a charge or shows signs of leakage, you'll need to replace it.
- Inspect for Damage: Since the lantern has been in storage for several years, carefully inspect it for any signs of damage or wear, especially around the battery compartment and electrical components. If you notice any corrosion or damage, it's best to address those issues before using the lantern.
By following these steps, you should be able to find replacement parts for your rechargeable lantern and get it back into working condition. If you encounter any difficulties, don't hesitate to contact customer support or seek assistance from a local retailer.
4/16/2024 9:58:57 PM •
Camping,...
Answered
on Apr 16, 2024
