20 Most Recent Packard Bell (181379) Motherboard Questions & Answers
Lost all system drivers for
http://support.gateway.com/support/drivers/search.asp?st=pn¶m=1009566
same motherboard
10/26/2010 8:18:34 PM • Packard Bell... • Answered on Oct 26, 2010
My computer only lights up then shuts down, then
change your power supply and check it again
3/7/2010 8:49:35 PM • Packard Bell... • Answered on Mar 07, 2010
There is no video at all. the computer is starting
Try reinserting the RAM. This is a common problem. If you have 2 ram modules, try changing slots.
2/10/2010 8:40:01 AM • Packard Bell... • Answered on Feb 10, 2010
2answers
I have a Tiny n19/Green900 17"
i have tiny n 19 laptop. the video card is gone,i looking for the video card. please help me! [email protected]
1/5/2010 1:39:48 AM • Packard Bell... • Answered on Jan 05, 2010
I have reloaded Windows XP after a crash. Can
yes you can obtain these on the manufactures website its fairly simple
12/29/2009 12:18:22 AM • Packard Bell... • Answered on Dec 29, 2009
Need to remove back panel of Easynote SW51-120 -
look for some clips on the side it should come off
11/25/2009 3:33:13 PM • Packard Bell... • Answered on Nov 25, 2009
2answers
I need a wep key for my ds but cant find it
-Go to Start-> Run
-type "cmd"
-at the dos prompt type "ipconfig /all"
-get your default gateway ip
-Go to your browser like Internet explorer.
-Type in that ip xxx.xxx.xxx.xxx.xxx
-That is your router setup where you can find the key or change it
-hope that helps
8/24/2009 8:59:26 PM • Packard Bell... • Answered on Aug 24, 2009
2answers
Motherboard Packard Bell EasyNote R6512
38ae9ee.jpg Hi Domingos,
Don't worry for your English, I'm french and mine is not so good...
The first component seems to be a diode : what is its indication near it on the mobo ("Dxxx" or "PDxxx" or what else) ? Check its resistance in both direction.
I don't recognize any fuse, and the orther picture is too far (components are too small), but you should look for indication like "Fxxx" or "PFxxx" or "FUxxx". Sometimes, fuses look like green resistor (flat and rectangular) with a cross on it like X. Just behind the diode it's a resistor because there is "R010" on it. However, check its resistance to be sure it isn't grilled.
When you put the power on the mobo, do you find voltage beetwin ground and positive pole of components ?
May be you could resend picture of the other side but nearer.
Hoping this help you...
FM.
8/15/2009 3:36:35 PM • Packard Bell... • Answered on Aug 15, 2009
Im 12 years old and i cant find my wep key on a
I would be suprised if you are using WEP. Most modern networks use either WPA or WPA2(which the DS does not support unfortunately) as WEP is older and insecure.
My suggestion would be to contact your parents or whoever manages your network and ask them how your network is configured.
6/3/2009 5:34:41 PM • Packard Bell... • Answered on Jun 03, 2009
Charging
If you can charge your battery in another notebook than borrow that notebooks power adapter & try it on your notebook with & without your battery in your notebook. Your power adapter may be devfective. Listed below is a link to your notebook. Included is all the updates for the,
Packard Bell Easynote R1935 Laptop
P/N : PB42B01001
http://support.packardbell.com/global/item/index.php?pn=PB42B01001&g=2000
please vote...
5/13/2009 12:20:30 PM • Packard Bell... • Answered on May 13, 2009
No Video PB Legend 2075
If your onboard video isn't working your only option might be to install a video card. You can also try checking if there any bios updates for your motherboard.
1/6/2009 12:23:41 AM • Packard Bell... • Answered on Jan 06, 2009
2answers
The screen of my laptop comes up with squares and small circles on reboot
Normally I would say this was a driver issue, however ,since you reformatted and reloaded your op system and it still does the same, I'm going to say it's either the inverter or the screen. Check the connections to make sure they haven't worked loose.
7/31/2008 4:48:25 PM • Packard Bell... • Answered on Jul 31, 2008
Easynote r1935
Chances are the notebooks adapter is broken. Take a look at this link & it will show & explain how to repair the jack.
http://www.laptoprepair101.com/laptop/2007/12/06/dc-power-jack-repair-guide/
Please read everything on the link.
If this is too tough to fix you're self. I suggest you take it to a pro. At least you'll all ready know what needs fixed.
Good Luck!
Mike
7/11/2008 5:19:39 PM • Packard Bell... • Answered on Jul 11, 2008
Packard Bell MotherBoard R6512 (PWA-8050MB/M BD
Hi Domingos,
Yes you're right !!! PF1 is the fuse and PD701 is the diode...
What are the results from measurements ?
Is the fuse grilled ? And is the diode OK ?
Do you have the voltage somewhere ? or is it shorted beetwen + and - ?
Regards.
Fox
3/21/2008 2:49:12 PM • Packard Bell... • Answered on Mar 21, 2008
Packardbell media
Have you tried using f8 during bootup and starting in safe mode? If not, once inside windows in safe mode you can adjust video settings, ect. Also, you can use system restore and go back to a point when things worked.
3/4/2008 7:25:06 PM • Packard Bell... • Answered on Mar 04, 2008
Beeping from motherboard
ladysharm,
Make sure that all of the plugs are plugged into the right places. Mouse ,Keyboard,etc..How does it beep? 1 time 2 times??
please post any beeps codes.
2/26/2008 5:43:33 PM • Packard Bell... • Answered on Feb 26, 2008
Old Packard Bell
try to see if bios jumper is in normal mode or pur battery off for a few minutes and see if it works
12/21/2007 4:09:18 PM • Packard Bell... • Answered on Dec 21, 2007
No Video
hi, ckeck Power Adapter, or RAM??
12/20/2007 8:10:35 AM • Packard Bell... • Answered on Dec 20, 2007
2answers
My motherboard makes a beeb sound
sounds like processor faulse
11/19/2007 9:38:36 PM • Packard Bell... • Answered on Nov 19, 2007
Boot
Since you forgot the password best thing to do is make the cmos forget it. The way to do this is remove the cmos battery. Take it out for several hours then put it back in. This will reset the cmos and you should gain access.
9/21/2007 11:58:55 PM • Packard Bell... • Answered on Sep 21, 2007
Packard Bell (181379) Motherboard Logo
30 questions posted
Top Packard Bell Computers & Internet Experts
Steve Sweetleaf
Steve Sweetleaf
Grand Canyon Tech
Grand Canyon Tech
Jose Ramirez
Are you a Packard Bell Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Packard Bell Computers & Internet
Most Popular Question
need wep key ds but find
  • Computers & Internet
