20 Most Recent
Ibanez MIMX65 Modeling Guitar Combo Amplifier 1x12 Inch, 65 Watts Questions & Answers
There's no sound when I put a cable in input, but when I put headphones too, there is a sound. How to reset ibanez mimx65?
If the sound you when plugging in the headphones is coming from the main speaker, it is just the interupt contacts on the headphones are making or breaking contacts. This can be a good sign if there is volume to it.Make sure the plugs you are using are the right length for jacks in the Ibanez as there are 5 lengths in use.. If this just developed, the length issue is not a concern. If the jacks are loose, snug them down, it may be a faulty ground relying on the chassis contact with the jack.. It may be a broken wire. It can also be a dirty switch contact or dirty level control, especially the standby switch. make sure they are clean with some contact cleaner. Make sure your level is turned up too, If you have effects, or a preamp on the guitar, make sure they have fresh batteries or good power connections and are not on mute.
What type of input Jack do I need for a ibanez guitar amp tbx30r?
i believe you need a 1/4" unbalance plug for the amps input. Basically a guitar cord. If I am understanding the question. ? or if you want to know the actual "input jack",Maybe it is lacking or missing? than that would be a "1/4" unbalanced input jack". good luck, I hope this helps.
8/26/2019 10:28:56 AM •
Ibanez Music
Answered
on Aug 26, 2019
CAN YOU TELL ME ABOUT THIS IBANEZ GUITAR SN 890453
Ibanez serial numbers were a patchwork over the years, very confusing, but most started with a letter. Those that did not were a 7-9 digit number.
I can't find anything that matches your number sorry. Hopefully someone else has better listings.
9/16/2017 3:13:20 AM •
Ibanez Music
Answered
on Sep 16, 2017
