20 Most Recent PNY USB SmartMedia Reader PC (SFRUSBWB) Questions & Answers
Hi i got a 256Gb usb and I was trying to put
You may have a defective flash drive if formating is not possible Most flash drives are formatted in xFat so that Mac's and PC's can recognize the same drive and still support files up to 4GB's
11/26/2017 7:20:14 PM • PNY USB... • Answered on Nov 26, 2017
2answers
My usb was suddenly says used capacity 0 bytes,free 0 bytes,
My usb was suddenly says used capacity 0 bytes,free 0 bytes,FILE SYSTEM raw.Cannot be formated.it says insert flash drive.give me the best solution
11/13/2015 1:34:54 AM • PNY USB... • Answered on Nov 13, 2015
0 byte 8 gig kingston
for usb drive with capacity above 4 GB , the most common problem is lost partition, for geeting the patition again you should create it manually with partition tools software like, acronis , magic partition or etc, that support to read usb partition. you could find it all within hiren's boot cd if you had one.
10/2/2012 9:20:16 PM • PNY USB... • Answered on Oct 02, 2012
My PNY usb key is
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems for a computer and its parts also click start control panel administrive tools ,computer management ,device manager scroll down universal serial bus controllers you should see a yellow question mark? right click to reinstall drivers or if you can see your usb drive but its not working ports(com&lpt)right click update driver or scroll to disk drives if you can see your drive + to expand right click you should see options to update driver,disable,uninstall scan for hardware changes. or select properties you should see options in the general tab to troubleshoot,policies,volumes,driver and details under the driver tab you will have the options to check the driver details,update driver,rollback driver or uninstall hope this helps don
2/16/2011 10:29:55 PM • PNY USB... • Answered on Feb 16, 2011
My one week old usb today said used capacity 0
This is probably a problem of system files on the USB key.
First of all, read the manual for the key, and verify that no utility provided with the key to reset or reformat. If such a utility is present, it is recommended that you used same before proceed to next step.
Otherwise, to reformat and therefore repair the USB key, you can use standard tools of Windows. Insert the key into the USB port of a PC, then go to:
Start / Control Panel / Administrative Tools / Computer Management / Storage / Disk Management /
Select the drive to the USB key in but ensure same is not a hard disk system!
Once the back up of your USB key effected, delete the existing partitions on the key (right click / delete the partition.). Format the key to FAT16 using all the available space (right-click / Format). For more than 2GB, it is recommended that you format same as FAT32.
If the available space is under the capacity of the key, this is surely a hardware problem, in which case it may be necessary to reduce the after-sales service.
It should be noted however that a difference of about 10% should not be considered, prior the way the manufacturer has recorded bytes. To be more appropriate, as a manufacturer considers that a Megabyte equals 1 million bytes or 1024 * 1024 bytes, a key of 512 MB can display 512 000 000 bytes or 488 481 250 bytes.
5/16/2010 12:03:59 PM • PNY USB... • Answered on May 16, 2010
4answers
Usb raw
wheres the solution ?
or am i blind ?
3/27/2010 1:00:30 PM • PNY USB... • Answered on Mar 27, 2010
Format with this tool.
http://en.kioskea.net/telecharger/download-127-hp-usb-disk-storage-format-tool
NB use server 2 for download. Server1 requires password.
3/24/2010 10:20:09 AM • PNY USB... • Answered on Mar 24, 2010
1 WANT INSTALL A PNY USB CARD READER WRITER, A
you should not need any drivers. just plug the card reader in an available usb port on your pc and you will be ready to go.
1/27/2010 7:53:04 PM • PNY USB... • Answered on Jan 27, 2010
Can't read SM 128 card on Vista or XP
The solution was that the SmartMedia card I was using seems to have been corrupted. It works perfectly well in my device to record music, but cannot be read through either of my computers. However, another SmartMedia Card does work and I have been able to download files, so it must be the card. The manufacturer of the MRS-4 recording device, ZOOM, say that they know of no way to repair the corrupted card.
Best wishes,
11/18/2009 6:56:49 AM • PNY USB... • Answered on Nov 18, 2009
Hi
Sounds like you may have removed it from sytem without ejecting first and this has caused a mini surge. You can try taking it to a reputable computer shop that specialises in data recovery but there is a good chance the device has had its day.
Sorry
Taz
11/10/2009 5:21:46 AM • PNY USB... • Answered on Nov 10, 2009
My ipod disk capacity show 0 byte plz help me
Reset the factory settings from ITUNES
9/13/2009 7:35:22 PM • PNY USB... • Answered on Sep 13, 2009
10answers
USB memory gives RAW message when used
Hi
You need to reinstall the USB drivers from the motherboard CD(the one you got with your PC)
2/1/2009 8:34:21 PM • PNY USB... • Answered on Feb 01, 2009
Disk full???
If Windows (you didn't say), try using Disk Cleanup from Accessories > System Tools. There could also be hidden files on it. In Control Panel > Folder Options > View click the box for "Show hidden files"
Hope that helps...
Geno
4/5/2008 9:41:10 AM • PNY USB... • Answered on Apr 05, 2008
2answers
Data recovery
There are many freeware and pay data recovery programs available on the web Try this freeware call smart Data Recovery http://www.smartpctools.com/recovery/ind... This is different from other recovery software because it not only recover lost file from harddrive and floppy like most do, but also recover from removable media like flash drive. http://download.cnet.com/pandora-recovery/3000-2094_4-10694796.html File recovery has never been easier thanks to Pandora Recovery. The program's wizard-like approach to finding and retrieving lost files will appeal to all users. http://www.piriform.com/recuva Accidentally deleted an important file? Lost something important when your computer crashed? Downloads to Recover Your Files and Save Your Bacon and 10 Best Free Hard Drive Utilities.
4/15/2020 10:09:25 AM • PNY Computers &... • Answered on Apr 15, 2020
2answers
Installation cd
go right to their website and download the appropriate driver/software and install it from your computer instead of the cd. incidentally, remove the cd from the drive and inspect the working side... the shiny side and see if it has any smudges or scratches. the cd player may not be able to read it.
it's not mentioned but is that a pc or mac and what operating system are you using ?
Robert
4/29/2019 9:08:10 PM • PNY Computers &... • Answered on Apr 29, 2019
FORMAT PNY 32GB
Try downloading and using the PNY format tool for 32GB flash drives: https://www.pny.com.tw/index.php?cls=2&mode=download https://www.pny.com.tw/index.php?cls=2&mode=download
11/20/2018 10:35:39 PM • PNY Computers &... • Answered on Nov 20, 2018
I have a 32gb Memory card that has a lot of
Try to scan the Memory card or Try to use bluetooth if the camera had bluetooth
11/14/2017 5:46:59 AM • PNY Computers &... • Answered on Nov 14, 2017
PNY USB SmartMedia Reader PC (SFRUSBWB) Logo
16 questions posted
Top PNY Computers & Internet Experts
goneforever.
rosefresh
rosefresh
Are you a PNY Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • PNY Computers & Internet
Most Popular Question
usb suddenly says used capacity 0
  • Computers & Internet
