20 Most Recent Power Adapter International Wall / AC Charger for the Krome Navigator F1 - Gomadic Brand w/ TipExchange Technology (B000XGTQ2E) Questions & Answers
I have the IQ 4522DJBT bluetooth speaker and i am having trouble charging my unit how do you know when its your power cord.
  1. Check the power cord for visible damage: Look for any frayed wires, cuts, or broken connections. If you find any damage, the power cord will need to be replaced.
  2. Try a different power source: Plug the speaker into a different outlet or power source to see if the issue is with the outlet.
  3. Use a different power cord: Try using a different power cord to see if the issue is with the cord that came with the speaker.
  4. Check the charging port: Make sure the charging port on the speaker is not damaged or obstructed. Clean it if necessary.
If these steps do not resolve the issue, the problem may be with the speaker itself and it may need to be repaired or replaced
4/5/2024 2:35:22 AM • Power Computers... • Answered on Apr 05, 2024
I turned on the power but no display
Because there's no current
4/4/2024 5:44:07 PM • Power Computers... • Answered on Apr 04, 2024
Brennan JB7 Digital Jukebox Amp shutting down.
Overheating would be the primary cause. Bad Caps possibly or even a dry joint on a component. The company is still going strong. They have a contact page, I would if they do 'refurbishment' or repair. https://www.google.com/search?q=Brennan+JB7 Shutting down problems https://www.google.com/search?q=brennan+jb7+shutting+down ..
3/17/2024 2:49:03 PM • Power Computers... • Answered on Mar 17, 2024
Realistic DX-390 won't power on with batteries or AC adapter.
Try removing the batteries overnight and see if it comes back on the next day. There are threads on a forum where this was the response: https://forums.radioreference.com/threads/thought-i-killed-my-dx-390.331818/
2/24/2024 12:33:11 AM • Power Computers... • Answered on Feb 24, 2024
Mastercraft router, tripped power and then stopped working. Looking how to get it apart and advise on how to fix it Mastercraft sears dustless router 315.244760 Tried it in different sockets
it is 40-45 year old router There are parts for it. I had one, tossed after bearings went out after minimal use.
2/21/2024 9:35:57 PM • Power Computers... • Answered on Feb 21, 2024
I pressed F11 and power button to factory reset my laptop and powered off before finishing. Now it says restoration incomplete and I click retry and it says that I need a disk to store 2MB IT
Factory resetting your computer destroys all the files on the hard drive. If you did not back up your files before running a factory reset, the computer might display a prompt to make a backup copy of your files before the reset performs any action that erases or deletes files. If your computer develops a problem, perform a Microsoft System Restore before performing a system restore. The Microsoft System Restore function returns the computer to a restore point, which resets all of the settings for the operating system to those settings that existed at the time the restore point was created. No personal data files, such as email, documents, or pictures are lost. For more information on Microsoft System Restore, see HP PCs - Using Microsoft System Restore.
2/19/2024 8:12:45 PM • Power Computers... • Answered on Feb 19, 2024
Instek PSP-405 bench power supply. Does enybody know the Instek part number or the manufacture part number of the display? Thank you.
You will only get that part from the maker.
PSP-Series Programmable Switching D.C. Power Supply
GW Instek https://www.gwinstek.com > products > detail > PSP-S... The PSP-Series is single output, 200W, programmable switching DC power supplies. OVL, OCL, OTP, and OPL protect the PSP-Series and its loads from unexpected ... ..
2/14/2024 8:30:24 PM • Power Computers... • Answered on Feb 14, 2024
MultiCat Litter Box by LitterMaid won't turn on.
  1. Check the power source: Make sure that the power cord is securely plugged into an outlet. Also, check if the power outlet itself is working by plugging in another device.
  2. Check the power switch: Ensure that the power switch on the litter box is in the "on" position. Sometimes it can accidentally get switched off.
  3. Reset the litter box: Unplug the power cord from the outlet and wait for about 60 seconds. Then, plug it back in and try turning it on again. This can sometimes reset any issues the litter box might be experiencing.
  4. Replace the batteries: If your MultiCat Litter Box by LitterMaid is battery-operated, check if the batteries need to be replaced. Even if it is plugged into an outlet, the batteries might still be required for backup power.
  5. Check for any obstructions: Inspect the litter box for any debris or waste that may be blocking the mechanism or sensors. Clear any obstructions and try to turn it on again.
  6. Contact customer support: If none of the above steps work, it's recommended to reach out to LitterMaid's customer support for further assistance.
2/12/2024 8:34:27 AM • Power Computers... • Answered on Feb 12, 2024
My pure mist free won't stay on after I turn it on.water is full. It's fully charged
Record which blue lights are flashing. Let the device sit for a few minutes and then turn it back on. If it still doesn't turn on, turn the device upside down over a sink to drain out any water that may have escaped to the base. Ensure you use Mypurmist ultrapure sterile water (do not overfill) and try turning the device on again. If the problem persists, please visit the Support page for further assistance. I list the link at the bottom of this reply. No Response When Pressing the Power Button: Check that the power cord is properly inserted into the *********** supply box and connected to a working outlet. Look for a green light on the power supply box; if present, the device should work. If not, please seek additional support on the Support page. Device Doesn't Turn On (No Lights): Plug in the charger and charge the device. It won't work while charging. If the device still doesn't turn on, ensure it's fully charged after approximately 2 hours. The red light will turn to green when fully charged. Water Dripping from the Bottom: It appears the device may have been overfilled. Turn the device upside down over a sink to drain any excess water. Refill with Mypurmist ultrapure sterile water (do not overfill) and turn the device on. Premature Red Light: Sometimes the red light may come on prematurely. Adjust the water level (add water) or reset the device. Avoid refrigerating the water used in the device. Red Flashing Light on the Back: The device has detected impurities in the water and won't turn on to prevent damage. Only use Mypurmist ultrapure sterile water for optimal performance. If incorrect water is used, please seek support on the Support page. Steady Red Light on the Back (Full Reservoir): If the reservoir is completely full of water, the device is functioning as expected. The red light indicates that the water needs to be refilled after a session. The fan will run for 10 minutes after turning off the device to dry internal parts. If you need further assistance, visit the Support page or contact customer service via email at [email protected]. Mypurmist Troubleshooting Guide ' Mypurmist Free Steam Inhaler FAQs
2/8/2024 7:09:01 AM • Power Computers... • Answered on Feb 08, 2024
I have a Bowflex BTX6 and it has power but screen shows "ble fail". Any experience with this problem?
According to the manual, the "ble fail" message indicates that there is a problem with the Bluetooth Low Energy (BLE) module. The manual suggests the following steps to resolve the issue: Turn off the treadmill and unplug it from the power source. Wait for 30 seconds and then plug the treadmill back in. Turn on the treadmill and check if the "ble fail" message is still displayed. If the message persists, contact Bowflex customer service for further assistance.
1/30/2024 7:51:12 PM • Power Computers... • Answered on Jan 30, 2024
Why does my powerfit E380 continue to beep and not switch on even with the remote controls
If your Powerfit E380 is beeping and not turning on despite using the remote control, there could be several reasons for this issue. First, check the battery levels in both the remote control and the Powerfit E380. Low battery levels may prevent proper communication between the remote and the device. If the batteries are not the issue, inspect the power connections on the Powerfit E380 for any loose or damaged wiring. Additionally, consult the user manual for troubleshooting steps, as there may be specific error codes or indicators that can help identify the root cause. If the problem persists, contacting Powerfit customer support for assistance may be necessary.
1/28/2024 11:43:59 AM • Power Computers... • Answered on Jan 28, 2024
How can I reset my Arlec Remote Controlled Power Outlet Model RC210
Unplug switch, plug in and while the LED is flashing, press and hold the All/turn off button. The LED will flash quickly, then it's unprogrammed when you plug it in again. (This is in the instruction sheet, BTW)
1/25/2024 3:27:08 AM • Power Computers... • Answered on Jan 25, 2024
Powercaddy fw5 left green light turned to amber
The charger has 2 indicator lights to represent the status of the battery during the charging process. When connecting a discharged battery, the red light will illuminate to indicate the bulk charge state. When the bulk charging process is complete, the green light will illuminate.
1/9/2024 11:52:06 AM • Power Computers... • Answered on Jan 09, 2024
CT-14CLS5CP(B) i went to know power mosfet number
It is printed on the component.
1/1/2024 8:22:54 PM • Power Computers... • Answered on Jan 01, 2024
My auvio headphones have a blue light that keeps flashing but does not connect
Ensure there is only ONE item connected to Bluetooth.
12/27/2023 8:02:42 AM • Power Computers... • Answered on Dec 27, 2023
Power Adapter International Wall / AC Charger for the Krome Navigator F1 - Gomadic Brand w/ TipExchange Technology  (B000XGTQ2E) Logo
1 questions posted
Top Power Computers & Internet Experts
vince
NOEL
NOEL
Are you a Power Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Power Computers & Internet
Most Popular Question
brennan jb7 shutting down
  • Computers & Internet
